Results 1 to 10 of 11
Thread: Dry damn you dry!
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Dry damn you dry!
    I've finish my charge cooler, even got the SFS silicon hoses to stick it in but the sealent is still drying!
    I want to put it in now!!!!!
    Looks like I might have to wait until tomorrow at the rate this stuff is curing...
    I know, I know you still want picture and I want to show you them but I haven't got any yet... I do have a camera and a computer though... I'll be back
    Dec 2005
    In the sponge-monkey tent
    Get a hair dryer and blow dry the sealant
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    umm... It might be a bit longer than I'd hoped.
    I don't think my choice of sealant was, ideal. Evo-Stik Liquid Metal isn't as good as it says...
    Once I've got the rest of it off me and the keyboard, I'll start again with a different addhesive.
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Mmmm, something smells nice! That'll be my charge cooler on convection at 70DegC .
    Not long now...
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    It lives!!!!
    I've had it in and running (hard), going to rolling road it at Red Dot tomorrow
    I got pics too! (note this months edition of TopGear)
    As you know dude figures aren't everything. What does your arseometer think? Is the car better to drive or not?
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    definatly, if only because the old prototype was leaking boost pressure which this one isn't.
    Don't have a mount for the boost gauge yet but I have the bits I need.
    Also, I've been working on the dump valve and have a plan... Dump valves don't just use a spring to hold the boost in, they use apposing boost. The dump valve is plumbed in before the throttle plate and a feed comes from the other side to the top of the dump valve. The pressure feed to the top of the dump valve acts on an equal or larger surface area than the dump feed. Along with the spring, this keeps the piston closed. When the throttle plate closes the pressure drops past the plate and on petrols produce a vacume. This vacume along with the pressure on the turbo side of the throttle plate open the valve against spring force and dump the pressure.
    Now if the spring were only very weak then simply removing the pressure from the apossing side of the valve should allow it to open. I have a solenoid selector valve rated to 10 bar which in it's self could act as a dump valve (cost me £30!). I could either use this by itself, or fit it into a line to open the servo line and allow boost pressure alone to open the dump valve. Alternativly I could use two of these valves, one attached to boost pressure and the other attached to vacume. With some simple normally closed and normally open relays I could then swap between boost and vacume to operate a dump valve.
    Theroy all sorted out, now the real question, will the ECU throw a fit? I'll try it just with the normally closed solenoid valve first to see if it gets stroppy and if it works okay, I could make a kit or just tell you want you need to use on any diesel.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    As above really Nut
    You ain't gonna win any style awards though LOL!
    Can see the concept. What's your induction system like these days?
    ECU wise I would say with that dump valve system would have a dikky fit.
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Looks like this, standard air box on the left with a K&N panel filter, a second cold air feed to the panel, a line from the top of the box to a second enclosed filter with it's own cold air feed.
    All the feeds face into head wind so I get load of flow.
    'Norf Yorks.
    Interesting Look forward to yer results
  1. Damn i need both of these.....
    By signum_rob in forum General Motoring Chat
    Last Post: 25th June 2012, 08:20
  2. god damn it!!
    By dahmich in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 10:59
  3. Damn car!
    By geebee007 in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2011, 23:05
  4. Damn it!!
    By Ben_ in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2010, 14:48
  5. Damn PVS........
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2006, 17:48
