Results 1 to 10 of 11
Thread: help..any ideas anyone???? please!!!!
    Regular Member howey's Avatar
    Oct 2006
    tyne and wear
    Default help..any ideas anyone???? please!!!!
    cant get my locking wheel nuts off as i dont have the key....also dont have the box it came in so cant get serial number, and vauxhall say the cant get it off the chassis number.... cant force a socket onto it as it has a outer rim on the bolt which spins....and im ready to shoot myself or the car....looked on a few sites but the things you buy (sockets) i dont think would work with this outer rim spinning
    any help appreciated
    Gis3.2 is the resident expert on those as he's removed several sets of Plasma's as he keeps losing his keys!! lol
    Plasma's now browsing now so I except he'll pop in a reply soon.
    Basically you have to drill the spinning collar and then you can fit on a ripper socket.
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    wot he said.. You need a ripper socket from someone like snap-on. not sure on what size, Gsi3.2 will know for sure. The spinning collar needs to come off. A sharp drill to drill through one edge of the collar, a chisel then used to split the collar off. Then the ripper socket can be whacked over it and then the nut can be removed.
    Oct 2006
    tyne and wear
    cheers lads...a big help..much appreciated
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    dude if the car has aa cover call them out and they should be able to remove it for you, if still under warranty then the dealers will replace them all f.o.c too, if not then as above have said m8
    Midlands Mod Shop - NFFC.
    Quote Originally Posted by plasma View Post
    exactly what he said.. i'll give you the snap-on part number for the ripper socket in the morning....
    Oct 2006
    tyne and wear
    what drill bits do you use as i bought the ones from b & q and it snapped three of them ????......dont laugh but im not diy complient
    Mileage : 000
    I would say you could use a drill up to about 10 m/m in dia I would try say 6 m/m or 8m/m and use a stud extractor to remove the broken thread. But MAKE SURE you drill it central so as not to drill into the thread in the hub.
    If you are not tooo sure about doing it I would suggest getting a mate who knows what he is doeing. you don,t want to compleatly knacker it up... good luck any way.
    Aug 2009
    slough
    Here is definitive info for anyone who has lost the socket or indeed it has broken.
    The Halfords £10.99 Laser tool does not work.
    This assumes you have the locking nuts with the spinning collar......
    1 - Hammer a multi point socket onto the spinning collar
    2 - Rattle it around with an air gun applying pressure in all directions - may take up to 10 minutes
    3 - This breaks up the insides of the spinning collar and will eventually come off.
    4 - Hammer a smaller socket over the inner part of the nut and undo
    5 - Geronimo you have fixed the problem !!
    Jul 2009
    sussex
    Quote Originally Posted by howey View Post
    i wouldnt waste your time drilling them, they are 10.9 bolts usually!
  1. Anyone got any ideas
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2011, 16:42
  2. Ideas Please
    By Tomb in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 16:21
  3. Any Ideas ???????
    By johnnyd2003 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:13
  4. Any ideas as to what this is
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2008, 21:21
  5. Any Ideas?
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 16:49
