Originally Posted by
spuddevans
I know what you mean, I had something very similar on my 03 Vec C, it would step out at the back on rough road or manhole and would do it pant-messingly-scarily at anything over 60mph!!!
Turns out I had 1 shot shock, the drivers rear had the tell-tale oil dripping down it, but also the upper control arm bush's on both sides had loads of play in them. Unfortunately you cannot get these bush's as spare's, none of my local motor factors could find one and Vx confirmed that the bush is not available seperately. ARRRRRRRGGGGGGGGGGHHHHH!!!!
The upper control arms, Genuine Vx part, cost 64+vat each, and like shocks should only be fitted in pairs!!! The good news is that there are a German non-official upper control arm available for 35+vat and according to the parts man in my local Vx dealer the german ones are exactly the same as the Vx ones, so you can guess which ones I got fitted.
I dont know the name of the geman manufacturer, but I got them through my local Vx dealer, charles hurst vauxhall in portadown.
Hope this helps mate, get a look at your shocks, and then check out the play in the rear wheels when they're both jacked up, if you've got play the most likely the upper control arms need replacing.
Tim
