Results 1 to 10 of 19
Thread: 2.2dti engine management
    Mar 2007
    north east
    Default 2.2dti engine management
    i have a strange problem which only happens in 5th gear.
    during normal driving when approaching a hill as expected you need to accelerate to keep power but as soon as i press the throttle the spanner comes on on the dash and limp home mode comes into play.
    So i turn off the ignition and straight back on again and everything is fine.
    This does not happen all of the time but maybe once every two days or so.
    The car is a 03 sri and totally standard with 47K on the clock.
    Any ideas, cheers.
    Feb 2006
    Guttedsville
    This is where my problems started.
    So far;
    New turbo, which is again knackered.
    Various 'Engine management' upgrades,
    Boost sensor,
    Vacuum Hoses,
    Boost Hoses,
    Wastegate and actuator,
    EGR Valve.
    First of all, check and double check the security of the boost / charge hoses. Look for splits or any signs of movement. After that, it really is needle in haystack time. Try giving the EGR valve a clean out too. Undo the two bolts holding it on, then douse it in carb cleaner. Let it thoroughly dry before refitting and restarting, or you'll have some comedy clown car pops and bangs out the exhaust! Sorry I can't be much more help than that.
    Good Luck.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    take it back to vx and get them to reprogram the ecu .....or you can legthen the turbo actuator rod ...wich will give you less boost
    Mar 2007
    north east
    thanks guys, i will check the charge hoses first and take it from there.
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    i think i have the same problem, yesterday on the way home from tint design, i had the car and spanner logo come on, but the thing is the car went in for its major service on the thursday last week, and they didnt pick up anything.
    I hope this isnt the start of something big.
    Mar 2007
    north east
    checked hoses and all look good, so i think i will eventually get it plugged in and see what codes are stored.
    cheers
    Regular Member david.aka.judas's Avatar
    Suffolk
    my 2.2dti has been an major thorn in my side.
    so far its had:
    3 attempts to balance the wheels
    1 ecu update
    1 suspension mod
    1 new front hub
    1 water leak fixed
    1 sim card update
    1 demister fixed.
    so I take it to exeter for a weeks holiday and the light comes on over 9 times in 5 days. took it to inchcape in exeter (nice ppl) and they say its has 4 codes present and they cant define which one has caused the problem. its booked in for next saturday, so I will let you know the outcome.
    I wish I hadnt bought this engine though, this is my 6th vx in a row and its seems a lemon.
    Goes like stink when its working though..........
    Mar 2007
    north east
    UPDATE: i have had a diagnostic performed and get the code P0234 which means hose connections,wiring,tc wastegate regulating valve or tc wastgate.
    I have thouroughly inspected and tightened all hoses/wiring and the fault still occurs.
    Now were the actuator arm connects to the waste gate there appears to be signs of a leak ( black soot).
    Has anyone any experience of this being repaired or is it going to be a new turbo ?.
    Suffolk
    UPDATE-
    the car went in for about the 10th time and it needed a new EGR valve, so they replaced that because it was causing the light to come on.
    guess what.........the light still comes on.
    Its going back in 2 weeks for a proper look..........dont you just love it.
    NOT
    Regular Member dervdoc's Avatar
    Co.Armagh
    well my 2.0dti does exactly the same but only started it when i fitted the tuning box, also i thought it make any difference adjusting the wastegate as its all controlled by the ecu anyway????????? is that true or false cause my wwagon isgetting plenty of fuel and wouldnt mind up'in the boost
  1. engine management
    By crazyvectra2013 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2013, 21:48
  2. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  3. Replies: 3
    Last Post: 28th April 2009, 19:49
  4. 2.2DTi Engine Management Light
    By MicSignum in forum Engine & Drivetrain
    Last Post: 19th April 2008, 14:39
  5. just had engine management done
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2007, 19:25
