Thread: oil leak from injector tube 2.2dti
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    Default oil leak from injector tube 2.2dti
    I'm after some info on this oil leak now appeared on the misses car its on one of the delivery tubes to the injectors I have taken off the cam cover and the injector is under the camshaft I have removed the securing bolt for the tube but can only move the tube silghtly front to back (don't want to break anything!!)anyone know how to get the tubes out???? its only the seal around the tube to the head thats leaking just can't work out how they come out
    any help from someone that knows please!!!
    Got a photo ?..which line do you mean?.. the fuel supply line? is it a diesel oil leak?
    its the tube that goes into the head (off the end of the injector pipes)its leaking engine oil around it (and making a right mess) with the top cover off the engine the tube goes over the top of the injector and is bolted at one end just can't figure out how it comes off the injector
  1. How do you change leak off pipes and injector seals
    By m.c.jones in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2013, 22:41
  2. injector pump leak
    By conmacirl22 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2012, 18:57
  3. 2.2dti injector seals
    By mickyp3 in forum Engine & Drivetrain
    Last Post: 13th July 2011, 22:06
  4. is changing the injector seal on a 2.2DTI a DIY
    By peadar in forum Diesel Engine related
    Last Post: 21st April 2011, 20:26
  5. Oil Leak 2.2DTI Help Please...?
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2010, 17:56
opel vectra 2.2 dti oil leak www.vectra-c.com
