Thread: 2 things missing on the wifes SRi
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Default 2 things missing on the wifes SRi
    First was a CD auto changer so fixed that by replacing the CD30 with a CDC40, no problem.
    Secondly she misses not having electronic climate control, I guess that's a bit harder to fit, if not please let me know. So she suggested that we just swap cars, I thought about this long and hard (1 sec) and discounted it, though I have promised when I get a VXR that she can have the GSI. Then she tells me that the 19s would have to go so there might at some point be a GSI running on SRI 17s, a first?
    May 2007
    Leeds
    confused Cdc40
    How did you go about replcing the CD30, just bought a CDC40 to upgrade my CD30 (bought 2nd hand so no manual, but do have sceurity code), installed fine but getting nothing through it, unsure how to enter the security code (on the CD30 you just push and the AS button, but no AS button on the CDC40). Confused.
    Nicking Ya Dinner.
    Climate has all sorts of things that aircon doesn't, it's a no go on that one I'm afraid.
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    I wonder if anyone could make something to look like climate control.. Surely it can be done, changing the knobs for buttons?? I assume that when a knob is turned, it sends a command to a computer to tell it to move the vent thingy's unlike older cars that were mechanically driven.. like my escort.. you could see the wire in the footwell, i pulled on it once out of curiosity and the knobs moved with it!
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by cheliboy View Post
    The CDC40 has to be Tech2ed from the donor car and then Tech2ed in to the new host, just like pairing a bluetooth device. If it hasn't been depaired/tech2ed from the donor then you have a very expensive door stop. Also the CDC40 is a full canbus HU. Is your car runing full or half canbus. SO unless you can get tech2ed nothing you can do. The donor may have done it correctly but your VX garage have to tech it in, check it out.
    exactly. if you haven't sen it tech2'd out of the other car, and it won't install via tech2 into your car, then it's scrap....
    Regular Member Karl's Avatar
    Sunderland
    Quote Originally Posted by willc01 View Post
    wow that sounds like a hassle!
    yep, but it stops then nicking the unit as it renders it un-useable, and the CD30 and above range are all nodes on the CANBUS, so need to be removed via the CAN network
    E Sussex & Kent
    Also for the CDC40 you need to change the monitor screen as well to the higher definition one. Full canbus , good point her SRI is a 55 plate pre facelift so no problem there.
    E Sussex & Kent
    Changed the aerial as well for the DAB one.
  1. wifes new car
    By stuart bigboy in forum Quick Photo Album
    Last Post: 14th February 2013, 22:22
  2. My wifes Sri
    By crayon in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2012, 23:20
  3. wifes car
    Last Post: 16th June 2011, 17:40
  4. wifes new car
    By amos in forum Non Vectra C/Signum Album
    Last Post: 23rd June 2008, 19:08
  5. my new toy,erm the wifes new car!
    By pogo in forum Non Vectra C/Signum Album
    Last Post: 15th June 2008, 12:04
