Thread: Recommend me a shower pump.....
    Regular Member Harry's Avatar
    Uxbridge, London
    Default Recommend me a shower pump.....
    As above really, can someone recommend a shower pump for a better flow of water. It's only going to service one shower and will be sat beneath the bath.
    B&Q are doing one for £100 - is that a fair enough price? from what i remember it's a 2bar one.
    any help and advice welcome.
    Here, there and every where!
    £100 for a 2 bar (positive pressure if your header tank is in the loft) pump is not a bad price. I've just done a quick search and none are cheaper than that so far m8.
    Uxbridge, London
    ta very much Tony - gravity fed system with header tank in the loft.
    no wonder they were completely out of stock!
    Just a thought, are you pumping both hot and cold to a shower head or just the cold to an electric shower?
    Screwfix have a twin pump for £94.99 LINKY
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by Caterman View Post
    this pump is a good one as i have fitted a few of them over the past months, easy to install and maintain and a good price from screw fix
    Midlands Mod Shop - NFFC.
    Uxbridge, London
    funnily enough i was flicking through the screwfix catalogue last nigth and spotted the exact same one.
    i'm pumping hot and cold to a shower head, so will definitely need a twin pump.
    ditchp - i may need to pick your brains a little more on this, as you've had first hand experience with this pump.
    looks like i'll be swinging by screwfix this week.
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    I'm upgrading our shower at the mo - does anyone know a way to gauge the mains pressure that is fed to my electric shower? I'm hoping there's something I can just screw onto the 15mm pipe to check (needs to be 1bar for my 10.8kW monstah!).
    As I can't fit a pump directly to the incoming mains feed, does anyone have any suggestions if the pressure isn't great enough? Would I be best taking a feed off the cold tank instead and fitting a pump to that?
    Regular Member stickshift's Avatar
    North London
    Quote Originally Posted by um20 View Post
    Here you go Fella via Froogle.
    http://www.toolmix.com/browse/produc...s52r=FROOGLEUK
    Regular Member robzc's Avatar
    Mar 2007
    South West
    Have you considered fitting a power shower? I know they cost around £150 for a decent one, but then you don't have any additional wiring or piping to do once installed.
    I recently installed a Galaxy G2000LX & it works great, just needed 2 x T pieces & some plastic 15mm tubing, did the job myself in around 3 hours, & I'm no expert. Everything is then gravity feed, no hi pressures to worry about, the pump is built in to the unit.
    Uxbridge, London
    i did think about it, but the long term plan is to rent the house out when we move in to our next one (fingers crossed) - and having a power shower will be just another thing to go wrong and for me to have to sort out.
    likelihood is that students will be renting it as we are only a stones throw from brunel uni, so i don't want to spend a fortune only for it to get wrecked. the pump is the easiest solution for a powerful shower in this instance
  1. Bath or Shower?
    By Happy Girl in forum The 'Off Topic' room
    Last Post: 2nd July 2011, 23:56
  2. Meteor Shower
    By ChrisBilly in forum General Chat
    Last Post: 3rd August 2010, 13:20
  3. Shower
    By moorlander in forum Comedy & Humour
    Last Post: 13th November 2008, 22:45
  4. anyone want a shower?
    By pogo in forum General items for sale
    Last Post: 11th November 2006, 10:41
  5. Walk in Shower
    By The Doc in forum General items for sale
    Last Post: 23rd August 2006, 00:19
