Thread: Vectra stereo
    Regular Member videodoctor's Avatar
    Blackpool
    Default Vectra stereo
    I have a 07 1.8 exclusiv and have set the stereo to not automatically come on when i put the key in.The thing is when i want the stereo on i press the button but when i turn the engine off and take my key out the stereo still stays on.Is there any way off turning the stereo off when i remove the key? ie some menu setting prehaps?
    Full Member Big Sig's Avatar
    Its because you have set it not to come on with the ignition. It thinks you want it on till you turn it off.....
    [Ex]Admin Duncan's Avatar
    Don't know if it changed on the facelift or is different on the other stereo models - but on mine (CCR2006) I've set it so that it doesn't always turn on when the ignition is turned on, but if I turn it on once the ignition is on it will turn off when I remove the key. If the unit was on when I removed the key, then it will turn on when I turn ignition on. If the unit was off when I removed the key, then it will not turn on when I turn ignition on.
    I wonder if it's just something that's changed with the facelift/stereo model?
    Quote Originally Posted by videodoctor View Post
    Thats how it was set on the facelift siggy I was loned - cd70navi. Maybe its worth looking in the manual?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    if you go into settings and it will say ign logic this is the setting for when you want the sterio on or of with the key
    Blackpool
    The ign logic in the settings brought the stereo on when you turned the ignition on and turned off when the ignition was off.Perfect except i dont want it coming on every time i put the engine on.But i do want it to go off when the ignition is off. ie i want to be able to turn it on manually but off automatically when the key is removed.
    Feb 2006
    dudley
    you cant have that .......either works with the key or dont .....but do look in the book to be 100% ....
    Quote Originally Posted by benny View Post
    Mine does - as per above post. Is that because it's a different unit?
  1. vectra stereo
    By merrick46 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 13:54
  2. vectra stereo
    Last Post: 2nd January 2012, 00:15
  3. Vectra C stereo? Is there any AUX in?
    By zsh in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2005, 10:05
