Thread: 12 v supply in boot of signum
    cambridgeshire
    Default 12 v supply in boot of signum
    Hi chaps quick question does anyone know of a suitable permanant live in the boot space of Signum to run a sub amp from, I had a look at the rear fusebox and nothing leapt out though there was a spare fuse holder but it seemed to be dead when I put a meter on it.
    I could do with 20 amps or so.
    Failing this I guess I am running a permanant live from the battery which could be a challenge.
    Any advice appreciated
    Ian B.
    [Ex]Admin Duncan's Avatar
    There's definitely a point in/around the fusebox you can use - somebody has done it. I've been meaning to add a 12V socket in the boot for portable cool boxes etc. but haven't yet so can't add any specific info.
    Have a search and hopefully somebody will come along with a link in the meantime.
    cambridgeshire
    Thanks Duncan I will have another search tried for about 10 mins and got nowhere pretty fast. 12v socket in the boot is very handy for the cool box in the summer that is for sure.
    Here, there and every where!
    There is a 12v supply in the rear fusebox but to run an amp i would not recommend it m8. I ran a fresh supply direct from the battery for mine.
    Ah yes, good point by Tony. It hadn't sunk in it was for a sub - so probably better to run straight from the battery, although more of a pain.
    Green Growler has a sub in his estate - not sure how he wired it though.
    cambridgeshire
    Oh well that is that then I shall be fitting more wire to the poor car.
    Mind you finding space for the amp is proving a challenge, or rather an amp that will fit the space (drivers side storage in boot, passenger side already full with CD changer).
    Thanks Caterman, any advice on the project?
    Yes m8, take you time or get someone else to do it
    It took me and my eldest 6 hours to fit my lot in. Sub, amp, head unit sat nav etc. Looked good after though.
    The longest job was running the power cable through the bulkhead. Take the glovebox out and there is a grommet you can get to from both sides and comes out behind the battery. I bolted the amp to the back of the sub box
  1. signum boot?
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2011, 22:25
  2. 12v power supply from boot?
    By Craig1985 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2011, 23:24
  3. Permanent supply in boot?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2010, 15:06
  4. signum boot
    By signum3.2 in forum Quick Photo Album
    Last Post: 25th January 2009, 21:54
  5. Signum Boot Mod
    By chrisf70 in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2008, 18:18
