Results 1 to 10 of 11
Thread: Continuous Damping Control (CDC) and TC lights on!
    Beirut
    Default Continuous Damping Control (CDC) and TC lights on!
    I've been having this problem on my 2006 Vectra 2.8l Turbo for a while now.While driving, the TC icon on the dash lights up and after 5 seconds the Continous Damping Control (CDC) icon lights up too (its the icon shaped like a suspension damper and has an exclamation mark next to it). I turn the car off and then back on, the icons are still on, i drive for 20 meters, they go off. After a short while they come back on! It's driving me nuts! And to add some icing to the cake, the tire pressure monitor icon lights up in yellow as well when this happens but not all the times.I took the car to the dealer's, they said they couldn't see anything wrong with the car when they had it plugged to their diagnostic machine. I insited and had an argument with them. They took car in for a day. When i came to pick it up, they said it was a broken tire pressure sensor and they changed all 4 under warranty and the car should be ok now. I think I drove 50 meters from the dealership and boom! All the icons were on again! Drove back and showed them. Same story. Next day, they said it was the main unit for the presure monitor sensors causing this and they changed it. You guessed it, all the icons on the dash still light up. The dealer doesn't have a clue on what is wrong. Car is still under warranty. Any ideas please?
    Beirut
    Anyone...? Any ideas? I searched the site and did not find anything on this problem or anything relating to it.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sorry mate there are not many of us with that system fitted to our cars. Give it a bit and keep bumping the thread and someone will come along to help you I'm sure.
    Sweden
    Not to many of us with CDC on here ... hadnt had any problem with mine.
    Not one of the dampers that isnt working as i should ?! ( just a guess )
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I don't have IDS+ neither, but according to the manual the icon refers to a problem with CDC or Sport-modus. I would think a fault must be registered (and that is what the manual says)
    Can you remark any difference if you push the sport-button?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i dont have anything like that fitted m8 but i would sugest calling the dealers and getting it checked out, if its a 2006 then im sure the warranty would cover any investigation / repairs
    Midlands Mod Shop - NFFC.
    Here, there and every where!
    As above m8, get it to the dealers. Tech2 should pick up any faults and as it is under warranty, repaired for free
    Beirut
    Thanks for the reply guys...will drop by the dealer's (AGAIN!!!) and give him a run for it...a long one this time!
    Cheers!
    This time INSIST they get a VX feild enginner out to the car if they can't diagnose and fix the fault..one of VX's guys will then come out to it, as they know more about the cars than some fitters.
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    its the serzo pump unit it went on my about 6 weeks ago £600
    Still under warranty
  1. cdc, continuos damping control
    By wazza in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2015, 09:24
  2. Led lights on my car and remote control
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2012, 22:23
  3. Silentcoat (Like Dynamat!) Sound Damping Mat
    By snapsnap in forum Parts for sale
    Last Post: 1st March 2011, 13:28
  4. Continuous damping fault light
    By rustywheelnut in forum Vectra C / Signum Troubleshooting
    Last Post: 31st March 2010, 18:39
  5. ABS Lights and Traction control lights
    By Dbus in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2010, 14:33
vrctra c damper light
