Likes Likes:  2
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Replacement turbo oil leak from return pipe
  1. #21
    Regular Member michale_kid's Avatar
    Feb 2015
    Love finding these old posts! Went to do oil change to find The bottom of My turbo and drain pipe is covered in oil and I'm praying it's this gasket. Would save alot of work!
    Just hope I can do it roadside as got a long trip over weekend.
    What can I clean the turbo and surrounding are with?
    Sent from my ONEPLUS A5000 using Tapatalk
  2. #22
    Full Member
    Mar 2016
    North York
    Engine : 1.9
    I've done mine in june. On my drive, only took bottom engine cover off and you can see oil return pipe. Tricky, but possible. Aprox. 25min. job.
  3. #23
    Feb 2015
    Quote Originally Posted by Lupus View Post
    Would have done mine roadside today but looks like the weather has other plans for me but does look easy enough
  4. #24
    Feb 2015
    Got a closer look and it's not the drain oil is actually coming from intake side of turbo where the inlet jubilee is connected
  1. Gasket on oil return pipe vectra 1.9 16v
    By geordieric in forum Engine & Drivetrain
    Last Post: 2nd April 2015, 20:30
  2. TD04 water return pipe
    By tamlynne2 in forum Engine & Drivetrain
    Last Post: 25th June 2014, 13:38
  3. Replies: 117
    Last Post: 8th November 2012, 15:03
  4. Oil leak from oil return pipe after fitting turbo
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 2nd August 2011, 15:00
1.9 cdti oil return pipe
oil leak turbo z19dth
boost pipe oil leak vectra
turbo feed pipe vectra c leaking
gasket for turbo return vectra
vectra c 1.9 cdti sri 150 oil around turbo
astra cdti 1.9 turbo oil return pipe
astra 1.9cdti dt turbo oil return gasket
1.9cdti 150 vectra engine oil leak
astra 1.9cdti turbo return pipe to sump leaking oil
vauxhall vectra cdti oil in turbo
oil leak from turbo return pipe seal
vectra d oil leak around turbo
turbo oil seal replacement
insignia oil leak
1.9 cdti turbo return pipe
1.9 cdti oil leak
common oil leaks Vectra C 2L turbo
vauxhall insignia turbo oil leak
vectra c turbo oil return
oil leaking from turbo insignia
vectra c oil feed pipe
z19dth turbo oil leak
how to test for turbo leaks 1.9cdti
oil leak under turbo vauxhall
