Likes Likes:  2
Results 1 to 10 of 24
Thread: Replacement turbo oil leak from return pipe
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    247 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Default Replacement turbo oil leak from return pipe
    So after being run up many times to ensure no leaks from anything after a lot of various jobs done on my car the garage will need it in again for a day next week as they just found a small weep of oil near the oil return pipe.
    Anyone have any advice about this as I've read a few times people putting new turbos on with all new parts like I have then it leaking. Previous to this even the garage agreed there should be no leaks as everything is brand new. They said it almost like it's coming from a join on the actual pipe itself which is odd.
    They have already checked all the bolts and doesn't look like it's coming from the brand new gaskets either.
    How did you guys solve your new turbo oil leaks?
    Teapot Tuned 245/300
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    New bolts, gasket and sealer, do it up tight...
    Oct 2013
    Derby
    247 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Thanks, it's not had new bolts as bolts don't wear out or affect clamping yes it's tight the garage are upset as everything's been done to ensure a clean seal.
    Ill mention using sealant when I pick it up as the new gaskets came with 2 rather than 1 which is lucky.
    Regular Member Wilson118's Avatar
    Mar 2014
    Scotland
    Vehicle : 1.9 cdti Sri
    Trim : Ex2
    Look anything like this?
    Oct 2013
    Derby
    247 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Dunno dude only garage has looked up there
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Did the garage use the cr@ppy paper gaskets or a genuine one with the copper washer?
    Oct 2013
    Derby
    247 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    All gaskets used on this are genuine Vx parts. The 2 gaskets for the oil return are just that no copper washers in that area only the supply side. That's unless I interpreted the parts diagram very wrongly any consumable that seals was replaced to avoid such an issue as this. The gasket from Vx that seals the pipe to turbo looked very paper like
    Mar 2012
    cheshire
    11 Post(s)
    Oil return from the sump is paper gasket, I had to add sealant to mine... Used new bolts for piece of mind when doing them up tight.
    Oil feed has copper washers, again I used new washers with new bolt...
    Think the gasket to the right was oil feed to the turbo, again I used sealant with the new gasket...
    Oct 2013
    Derby
    247 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Cheers it's banjos both ends of the feed as its high pressure and gaskets both ends of the return. The first in your pic has a kind of coating it's the smaller one that fits on the turbo that's papery
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    If it's leaking between the underside of the turbo and the oil return pipe, the genuine Vauxhall gasket has a copper washer within the gasket.
    Thats where mine is leaking from presently. I have a genuine gasket waiting to be fitted. I'll get a pic and the part number in a few minutes.
  1. Gasket on oil return pipe vectra 1.9 16v
    By geordieric in forum Engine & Drivetrain
    Last Post: 2nd April 2015, 20:30
  2. TD04 water return pipe
    By tamlynne2 in forum Engine & Drivetrain
    Last Post: 25th June 2014, 13:38
  3. Replies: 117
    Last Post: 8th November 2012, 15:03
  4. Oil leak from oil return pipe after fitting turbo
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 2nd August 2011, 15:00
1.9 cdti oil return pipe
oil leak turbo z19dth
boost pipe oil leak vectra
turbo feed pipe vectra c leaking
gasket for turbo return vectra
vectra c 1.9 cdti sri 150 oil around turbo
astra cdti 1.9 turbo oil return pipe
astra 1.9cdti dt turbo oil return gasket
1.9cdti 150 vectra engine oil leak
astra 1.9cdti turbo return pipe to sump leaking oil
vauxhall vectra cdti oil in turbo
oil leak from turbo return pipe seal
vectra d oil leak around turbo
turbo oil seal replacement
insignia oil leak
1.9 cdti turbo return pipe
1.9 cdti oil leak
common oil leaks Vectra C 2L turbo
vauxhall insignia turbo oil leak
vectra c turbo oil return
oil leaking from turbo insignia
vectra c oil feed pipe
z19dth turbo oil leak
how to test for turbo leaks 1.9cdti
oil leak under turbo vauxhall
