Thread: Strange problem
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    Default Strange problem
    Earlier I got in my 2.0DTi (Y20DTH) and started it up. Car/spanner light on. It does this sometimes but then goes off as I set off, but this time it didn't and the car sounded like it didn't have an exhaust on and no power. Then after about 20 seconds noise went away and did the warning light. Would it sound like there was no exhaust if the EGR was stuck open?
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    Car did the above again today after I picked it up from passing its MOT. This time I set off and then the car cut out. Started up again straight away and EML went off and drove fine. Any ideas?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    If your spanner light comes on with the ignition and goes off when the engine has started, it is usually an indication that your cars electronics have logged one or more fault codes. Once read, these codes can point towards the cause of problems.
    A decent code reader from ebay shouldn't cost much more than £15 and is a really useful addition to a Vauxhall car driver's toolkit.
    Taking the car to a main dealer to get their equipment plugged in, can set you back around £50 so it should pay for itself fairly quickly.
    HTH
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    I borrowed a snap on bluepoint (or something like that) from a friend last year but there was no commutation. It worked on his 2005 CDTi. I did some research and as far as I can tell a lot of readers don't work on pre 2004 diesels. Could anyone recommend one around £15 that works with a 2002 Y20DTH. Thanks
    Sent from my XT1072 using Tapatalk
    Feb 2012
    North West
    Trim : Exclusiv CDTi
    If you know anyone with OPCOM or VAUXCOM these will read the codes, or post a request in your regional group, some kind member might plug theirs in for a few beer tokens.
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    Turned out to be my crankshaft sensor
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Was that after a friendly no cost code read from a local member ?
    Or, was it a FULL and OVERPRICED diagnostic from a main dealer solution ?
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    It was a friendly low cost code read from a local member. Thanks Zudrick
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Nice one @zudrick
  1. Strange HID Problem
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2015, 21:31
  2. Strange problem.
    By Chad! in forum Engine & Drivetrain
    Last Post: 13th October 2011, 14:18
  3. Strange problem
    By Graeme in forum Bodywork & Interior
    Last Post: 19th March 2011, 15:22
  4. strange problem
    By darko2301 in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2009, 12:18
  5. Strange problem
    By kevster in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 12:59
