Thread: Exhaust Help
    Regular Member danlat1415's Avatar
    Lancashire
    Default Exhaust Help
    Hi,
    I've fitted a SRI rear bumper last weekend, and just managed to fit the SRI Backbox.
    Is there an adaptor available to make a smaller exhaust pipe (on my 1.8 SXi) bigger to fit the SRI backbox?
    I've done a temporary fix of cutting some pipe and sticking it in the end and sealing with some GunGum, but it's not a permanent solution because the pipe isn't tightened, so the tailpipe is able to move from side to side in the exhaust outlet.
    I've seen some custom made exhaust adaptors on Ebay but they are £14?? you tell them the sizes and they make it.
    But are there some pre-made ones available on retail? or is anyone a master with the pipe and can do one cheaper?
    I couldn't find any at Halfords, so went to another local store and they only did one size (and even the larger end of that was smaller than my small pipe.
    Long story short, I'm after an adaptor of some sort to make my small exhaust pipe, fit the larger pipe'd SRI backbox.
    I don't know the pipe diameters so ANY will will be greatly appreciated.
    Mine is a 52 plate 1.8 SXi
    The backbox is Spoons old one... can't find it on the forum anymore as it's been deleted.
    Dan
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    road runner in notts do them, dont know how much or the sizes just know i got one from them a while ago to mod an xr2 peco box to an old mini.
    they are on the web so give em a look, you never know your luck m8
    Midlands Mod Shop - NFFC.
    Lancashire
    Does anyone know the pipe sizes? so I can contact a few companies and ask around. I found roadrunner http://www.roadrunnermotorsport.co.uk/ so when I get the pipe diameters, I can order one.
    I'm not sure, but an educated guess would be:
    2.5" (63.5mm) then 2.1" (54.0mm) pipe diameter
    Can anyone confirm this, so I can get a pipe ordered.
    Dan
    Lancashire
    Just measured the old backbox I took off, and it had a diameter of about 43mm, but if anyone knows the official measurements that would be very helpful.
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    There's some further info on the twin exhaust setup in this post, note sure how much applies to the 1.8 tho, sorry.
    http://forum.vectra-c.com/showthread...highlight=54mm
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
