Thread: Trim Changes
    Regular Member danielpayne's Avatar
    Basingstoke
    Talking Trim Changes
    After seeing a newer Vectra in a VX workshop the other day I thought I'd make this trim changes... (apologies for the poor images used my mobile)
    From this
    To (bad light)
    From this
    To
    From this
    To
    From this
    To
    I also brought the silver section for the bottom of the steering wheel as used on the new Astra but the colour match was poor (silver against brushed steel). And those of you with good eye sight will notice the 24.6MPG!!
    i bet that lot cost a few beer tokens!
    Basingstoke
    not bad for £85.
    Regular Member Basil's Avatar
    Nottingham
    A subtle but nice improvement there mate, nice one, just a couple of questions if you don't mind me asking
    Were they easy to fit?
    How much were they individually?
    And finally, did you get them from VX or can you get them cheaper somewhere else?.
    (Just the vents by the way not the gear surround)
    Basingstoke
    They were really easy to fit the sides took about 2/3 minutes each and center a little longer (10 mins) because I had to unscrew the screen, I didn't pull of the multi-plug thru fear of the screen going into safe mode. Basically pull off trim under the vents and out with the screws.
    The sides were £16.05 each and the centre £28.65 direct from VX here's the part numbers;
    lh = 13150882
    rh = 13150881
    centre = 13150880
    Nottingham
    Oops, just noticed that I already have them in my car as standard, sorry bout that, hope I didn't put you to to much trouble getting the info.
    Thanks anyway
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Not to bad a price and it makes it look tidier too
    a bit off topic mate but what is that on your trip computer screen underneath the fuel mpg figure, the thing that looks like it says 22 in each of the bottom corners.
    anyway, my 05 54 had those as standard, and the silverline panel across your dash and doors is the same colour on mine as the vents, very classy.
    Thats the climate control (instead of standard AC) variable temperature for either side of the car.... Elite and GSi models as standard.
  1. SXI trim
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2007, 03:53
