Results 1 to 10 of 11
Thread: Radiator Warning light on first start of every day
    Regular Member Darrell's Avatar
    Feb 2007
    Wolverhampton
    Default Radiator Warning light on first start of every day
    Anyone got any ideas on this one.
    For the past 5 days i have a radiator light come on the dash on the first start up each day. Once run a couple of minutes, its gone if i turn ignition off and back on. If on first start i take a 6 hour journey it would prob stay on, only goes out when i turn ignition off and back on again. And wont return till first start tomorrow.
    No running problems or anything.
    I would have thought this would be caused by the coolant level sensors
    There could be air in the system
    Try this :
    Purchase about 3 litres of coolant, and mix up a 50:50 6 litres ready for use
    With the engine cold, remove the coolant cap
    Allow the engine to warm up on idle, there will be some coolant loss
    Allow the engine to cool
    The system should return back to its previous level, less any lost (but there shouldn't be that much)
    Measure how much coolant you need to add with the engine cold
    Replace the coolant cap and retry
    Regular Member CBR600FV's Avatar
    Wales
    I know it might be stating the bleedin' obvious but is the header tank level low? I had mine come on on Mon when going round a long bend, stayed up until IGN Reset. Level was ok in the Header Tank. Did notice the sensor was set into the bottom of the tank.
    Normally the driver display comes up "Coolant Level" when the header bottle reservoir is just below its minimum
    The radiator warning light normally only comes on if there is NO coolant in the radiator or the coolant system temperature is too hot
    it's so easy this one.... is the coolant level on the line or not?..
    if it's on the line when cold, yet the light comes on, swap in a new coolant sensor...it's the only thing at fault in the header tank...it wouldn't be the 1st one i've changed..
    right, but the guage would tell him if it's too hot, and if he can see coolant in the tank then it's not running short..or airlocked...and he says they're no running problems which would tend to rule out running short of coolant as that would cause overheating problems..if it was running short the location of the temperature sensor would make it run in steam effectively..and that would send the temp guage crazy..
    Another possibility is if the car is parked overnight at an angle
    I had this on my previous Vectra
    Checked and the coolant was bang on perfect
    Parked the car and "coolant level" kept appearing!
    wow, that'd have to be some angle to drop the float that amount...thou the veccy b float arm was never that good..
    Mileage : 000
    I agree with Mark.
    Feb 2007
    Wolverhampton
    yeah was level, appears my drive is more sloped than i thought, was below cool level but not that low, the slope just made it appear worse.
    Thanks for all replies
  1. Warning Light on start up.
    By stujrox in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd January 2013, 11:34
  2. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  3. Radiator water level light?????????
    By jase44 in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2009, 20:25
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
vauxhall vectra coolant warning light
why is my vectras coolant warning light coming on wen level is fine in tank
vauxhall insignia coolant warning on startup
vectra c radiator warning
coolant warning vauxhall insignia
