Results 1 to 10 of 13
Thread: Leather 4 spoke steering wheel, buttons & airbag
    Regular Member Vectra_Power's Avatar
    York
    Thumbs up Leather 4 spoke steering wheel, buttons & airbag
    I have found a steering wheel that I'm interested in (3 spoke SRi jobbie) and therefore my wheel will be surplus to requirements. The wheel is currently fitted to my 52 plate Vectra C Elegance.
    The airbag is in very good condition with no damage. The wheel itself is in good overall condition, with only a couple of small marks. The is wear on the wheel, but it still feels nice to hold.
    I'm looking at £100 ovno for the wheel, see pic below.
    Thanks,
    Chris
    07932 214466
    The new wheel you're looking at still has the six button controls? If it has the rocker switches then they won't fit the connector underneath on your car.
    Just thought I'd mention it in case you hadn't realised.
    Forgot to say....
    Your 52 plate will only have one airbag connection in the car. They changed from one connector to two connectors in MY 2003.5 (May 2003) so you'll need to make sure the new airbag is from a car from then, or before, to fit your car.
    York
    It does mate as it is from an 03 SRi, it even has the silver button surrounds I was wanting, result.
    Are the airbags easy to remove?
    York
    Forgot to say....
    Your 52 plate will only have one airbag connection in the car. They changed from one connector to two connectors in MY 2003.5 (May 2003) so you'll need an airbag from then or before to fit your car.
    I better check that, I thought the one to two wire connection changed in 2004! It would be typical if it was different!!
    Quote Originally Posted by Vectra_Power View Post
    Yep - BUT MAKE SURE YOU DISCONNECT THE BATTERY AND LEAVE FOR 10 MINS before starting to remove.
    York
    I will make sure I do that mate (I have done a few in the past), are there holes in the back of the whell that I can place a screwdriver into to release the wheel? Any techniques I need to employ?
    Cheers!
    http://forum.vectra-c.com/showthread.php?t=10904
    That should sort you all out!
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Turn steering wheel 90 degrees from straight. Push screwdriver in and twist, one side will pop out. Twist 180 degrees and repeat.
    Done
    York
    Quote Originally Posted by The Doc View Post
    Done
    Excellent, cheers guys.
    I have emailed the guy selling the wheel to establish if the wheel is definately from a 2003 and how many connectors the airbag has!!
  1. leather 3 spoke steering wheel and airbag for sale
    By mhvcbv in forum Parts for sale
    Last Post: 9th July 2010, 18:10
  2. 4 spoke leather steering wheel, Rotary (Canbus) Buttons...
    By Paddy2bsure in forum Parts for sale
    Last Post: 18th June 2007, 13:48
