Thread: steering wheel radio controls
    Mar 2007
    Hull
    Default steering wheel radio controls
    when i bought the 1.8sxi, the radio controls on the left hand side of the steering wheel dont work, they dont even light up when lights are on. will this be a fuse or are they only available on different modles? like the LS for example.
    and i would like to start making the exterior look better, where can i get hold of smoked headlight and eye brows?
    cheers guys
    Jan 2006
    Skynet HQ EMEC#5
    All controls work on my 1.8 SXI, could it be a bad connection or fault with switch?
    i'd try a faulty wiring loom within the steering wheel as the reason for the buttons not working..but thats an airbag off job.. not to be done unless you're 100% with what you're doing..
    Oct 2006
    Wellingborough
    Is it the factory fit radio or an aftermarket unit? if it's after market they may not have fitted the adaptor cable to retain use of steering controls.
    yep, but if that was the case then neither side would work...
  1. Steering Wheel Radio Controls
    By j62k in forum Electrical & ICE (including SatNav)
    Last Post: 20th October 2008, 14:41
  2. Steering Wheel Radio Controls
    Last Post: 19th October 2008, 14:22
  3. Steering wheel radio controls on a B
    By stripey in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2007, 20:54
