Thread: key fob
    Feb 2007
    airdrie
    Default key fob
    my key fob went all weird on me today, when i pressed to open the windows went down and vice versa when i locked it, now it wont work at all, it only does this with my set, the wifes set is fine
    anyone help at all
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    the windows only open & shut when you keep the lock or unlock buttons pressed (as im sure you know) might be worth taking it to the stealers to get it tech 2'd again & see what happens perhaps
    Feb 2007
    airdrie
    now the wifes doesnt work my battery has leaked and its possible that hers is dead so its down to the dealers to have a looksy
    Yea afraid so then mate never had this problem myself but am pretty sure they gotta be tech 2'd when the batterys are changed
    they only need tech2 if they are without power for more than 30 seconds..so if you're quick changing the battery you may be lucky...thats not an open case for 30 seconds, it's no battery on the contacts for 30 seconds.
    If the battery is totally shot you may need tech2 to 'teach' the car the remotes again..
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    When i changed the batterys in my remotes the car wouldn't lock/unlock,turned the ignition on and off then all ok again.
