Likes Likes:  5
Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
Thread: What do I need to change from an M32 to F40 gearbox
  1. #61
    Oct 2018
    BG
    Vehicle : VECTRA C
    Trim : Estate
    Engine : Z19DT
    Quote Originally Posted by Drogen24 View Post
    Sorry to necro this old thread again. Does anyone know if an f40 from a pre-facelift 150 will fit a facelift 120? I've found a potential donor car that I can get all the required parts from for much cheaper than an M32 alone.
    Can anyone confirm the latest post about the flywheel being the same or will I need a Z19DTH flywheel?
    Preface F40 will fit, but it's better to find as much newer(less km) as possible from last facelifts, because F40 has wear issues with input shaft bearings.
    Flywheel is related to engine model(not clutch/gearbox) keep 8v one, if you want to put new, has to be again for 8v engine.
  2. #62
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    Hi folks.I have an insignia mk11.8 and interested in swapping m32 to f40 box. Which box will work as per ratios. Anything needed to swap? Many thanks
  3. #63
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Quote Originally Posted by pauluk49 View Post
    you might want to post this in the Insignia section mate
  4. Likes Dog_Book liked this post
  1. Change the oil in an M32 gearbox
    By fatfred in forum Engine & Drivetrain
    Last Post: 28th September 2014, 21:34
  2. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  3. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
difference between m32 and f40 gearbox
https:www.vectra-c.comforumshowthread.php217142-What-do-I-need-to-change-from-an-M32-to-F40-gearbox
1.9 m32 f40 swap
m32 or f40 gearbox
f40 gearbox
m32 gearbox to f40
f40 or m32 gearbox
vauxhall f40 or m32 gearbox
will a f40 gearbox fit a 1.8 xer
vectra f40 or m32
difference between f40 and m32
F40 gearbox in what carsm32 to f23 conversionm32 vs f40 gearboxchanging my gearbox from an m32 to an f40https:www.vectra-c.comforumshowthread.php217142-What-do-I-need-to-change-from-an-M32-to-F40-gearboxpage6https:www.vectra-c.comforumshowthread.php217142-What-do-I-need-to-change-from-an-M32-to-F40-gearboxpage4vectra c battery tray removalon a Vauxhall Insignia what is the difference between an M32 gearbox and an F40 gearboxconversie insinua m32 f40what is the difference between an M32 and F40 gearbox on a Vauxhall Insigniadirrance between f40 amd m32 clutch kitsm32 clutch bleed site:www.vectra-c.comvauxhall vectra 1.9 cdti clutch bleeding site:www.vectra-c.comdiff m32 f40
