Likes Likes:  5
Results 1 to 10 of 19
Thread: Interior light
    New Member MrTuco's Avatar
    Apr 2015
    Market Harborough
    Vehicle : 2005 Vectra estate
    Trim : Life
    Engine : 1.8
    Default Interior light
    I am a forum virgin so please accept my apologies if I am getting this all wrong, tried FAQ with no luck. 54 Vectra 1.8 estate, interior lights not working, bulbs are good, boot lights are ok but front interior not working.. please help..
    VIP-Member TheEpicSponge's Avatar
    Apr 2014
    Wallasey
    10 Post(s)
    Vehicle : Lexus IS250
    Trim : SE Auto
    Engine : 4GR-FSE
    Year : (56)
    Mileage : 79000
    Look in the fusebox on the passenger side of the dashboard. I had the exact same issue when I first got the car. Look for a blue-cased fuse in the middle of the box. I can't remember the amp or fuse number, but it's the fuse that controls the interior light, trip distance, clock lights and aircon lights.
    change the fuse and you should hopefully be all good!
    Apr 2015
    Market Harborough
    Trim : Life
    Engine : 1.8
    All the fuses are good. This is the only thing not working.....
    Apr 2014
    Wallasey
    10 Post(s)
    Trim : SE Auto
    Engine : 4GR-FSE
    Year : (56)
    Mileage : 79000
    Are your clock lights and aircon/climate control lights coming on when you turn the sidelights on?
    Apr 2015
    Market Harborough
    Trim : Life
    Engine : 1.8
    Yes all the other lights are good even down to the symbols on the light fitting when I open the doors or turn the lights on. I am getting an earth and a live at the plug. These are operating correctly when the doors are open, but I have no map lights or dome lights even when buttons are pressed. I have changed the unit as well. Any ideas?
    Regular Member jugsta's Avatar
    Apr 2015
    wigston leicester
    Vehicle : vectra c
    Trim : cdti diesel 150 sri
    Engine : 150
    Mileage : 160k
    Hi did you sort it as I have same prob, boot light come s on when I open boot,and. Dash lights,light up ok ,but no front or rear interior or passenger or drivers mirror lights.they all worked before but just stop working ,checked all the fuses on pass fuse box ( mines a vectra estate 2008 cdti Sri ,any help would be good
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    205 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Try looking in the troubleshooting section under electrical / interior someone might have had the same issue you have.
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
    Apr 2015
    wigston leicester
    Vehicle : vectra c
    Engine : 150
    Mileage : 160k
    Thanks dog_book ,just looked through the manual to see if I could find the fuse number to check that but no luck,but glove box and boot light still work and side light switch illumination etc,as sure it used to come on on the fob key when pressed and that no longer comes that way either
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 10000
    Have you physically checked the bulb to see if it's OK? they are just the 501 sidelight bulbs and don't last forever.
    Alan
    Apr 2015
    wigston leicester
    Vehicle : vectra c
    Engine : 150
    Mileage : 160k
    Hi yes had a quick look at the 4 front bulbs in the interior light (front or rear don't work Sri cdti model) but they all ok
  1. Replies: 1
    Last Post: 25th September 2014, 17:01
  2. Drivers door,interior light,warning light,dead locking issue.......
    By beggsy in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2014, 19:00
  3. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  4. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
vectra interior light fuse
where is the fuse for interior lights on vectra c
vauxhall vectra c estate front interior light not working
vectra c interior light
