Hi guys i have a 09 plate vauxhall insignia elite .I'm after some help in removing all the wood effect trim around the stereo/dash and the peace that's on the drivers and passengers door . any help would be appreciated on how to remove thanks .
Straight forward m8. First start at the ashtray the trim around it clips out then the one next to radio clips off and the same idea on the pass side the parts on the doors are clipped in but cannot remember if you can remove them without taking panel off
Yes door trims and the ones around the top of the
dash panel just clip off,they are very tight so be
carefull.
No need to remove door panels.
Thanks guys I'll be giving it ago tomoz afternoon
Just a quick update I managed to get all the trims off without breaking them ha! I do recommend taking door cards off to remove the trims makes life a lot easier . ☺
Pleased you managed ok.
just bought a Haynes manual for mine,less than £15 on fleabay very good section on trim removal,also got a set trim tools for £4.99(fleabay)
