Likes Likes:  1
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Momentarily Heavy steering 2006 1.9 CDTI
  1. #11
    May 2014
    Liverpool
    11 Post(s)
    Vehicle : Vectra facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Finally got round to getting time to get this sorted, changed the steering pump and rack. Problem solved, think it was the rack that was at blame as you could feel it when turning the wheels by hand, while up on the ramp.
  2. Likes 150Estate liked this post
  3. #12
    Nov 2009
    Warwickshire
    Quote Originally Posted by Ren Vx View Post
    Had the fluid in the system changed, came out grey, as soon as he put the fresh fluid back in that instantly changed grey too.... I've sourced a rack and pump so just going to get that all changed for piece of mind.
    Vx mechanic told me steering fluid gets forgotten - check it every oil change for level and colour - it should be green and clean - change it every 50k.
  4. #13
    Nov 2020
    Wirral
    Vehicle : Vauxhall Vectra C
    Trim : 57 reg 1.9cdti SRi
    Engine : 1910 diesel
    Quote Originally Posted by alcutler View Post
    Have you checked alternator and battery are working properly
    Another answer could be an Angle Sensor? I bought a used one 5 years ago for £10 from a scrap yard. Problem fixed until this week. Think I've worked it out to a faulty connection now on the plug
  5. #14
    Feb 2021
    Dorset
    Trim : Sri
    Engine : CDTI 150
    Year : 2008
    I think this is the same issue I have �� where did you get your rack and pump from and roughly how much was it to get it changed?
  1. heavy steering
    By lh_4827 in forum Suspension, Wheels & Brakes
    Last Post: 2nd March 2013, 17:38
  2. very heavy steering
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 19:10
  3. 1.9 Momentarily Cutting Out
    By Homer in forum Engine & Drivetrain
    Last Post: 17th June 2012, 10:07
  4. Steering is a little heavy and juddery
    By freshprince in forum Suspension, Wheels & Brakes
    Last Post: 21st August 2008, 11:57
  5. Steering heavy HELP !
    By cpt slow in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2006, 09:03
https:www.vectra-c.comforumshowthread.php216474-Momentarily-Heavy-steering-2006-1-9-CDTI
vectra c stiff steering
Opel signum steering wheel problemshow to replace steering rack on vectra 2007 cdtiastra 1.9 cdti stiff steering wheelVauxhall vectra c steering going stiffzafira steering sometimes stiffvectra 1.9cdti power steering noisesteering system tight on vectra cvectra c steering racksteering feels stiff sometimes on vauxhall vivarosteering rack joint vauxhall vectravauxhall vectra 2008 power steering really stiffvectra c notchy steeringsteering heavy foot on brake turning power steering vectra cvectra steering heavyvectra c power steering pump contactsvectra c steering goes heavynotchy steering astra hvauxhall movano power steering goes heavycommon cause of heavy steering on vectra cdtivauxhall vectra c heavy steeringVectra cdti steering heavy when turning rightstiff steering vauxhall vectravauxhall.vectra design. steering heavy
