Likes Likes:  1
Results 1 to 10 of 14
Thread: Momentarily Heavy steering 2006 1.9 CDTI
    May 2014
    Liverpool
    11 Post(s)
    Vehicle : Vectra facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Momentarily Heavy steering 2006 1.9 CDTI
    I've been having this problem for a while, I've had the car checked and there is no physical sign of a problem so getting to the point where it's going to be changing parts to eliminate the problem.
    It's hard to explain but if you are driving along a sweeping bend the steering will feel as if the power assistance isn't there, then all of a sudden it will be making the wheel jerk because of the force that I'm using to turn the steering wheel. The springs have not long been changed for brand new H&R's and at the time the bearings where moving freely by hand, maybe this could be changed with the weight of the car sat on them, with the car on axle stands the wheels will turn freely left to right with no sign of the problem. Maybe steering rack or pump.
    I'll be changing the top mounts and bearings through the week once I am back from a long weekend break to Wales, as this is the cheaper option out of the parts I think could be the problem.
    The car has also had 2 lower arms (one last week the other about 7 months ago, droplinks (saab uprated ones) and steering rack ends and track rod ends fitted.
    Also had someone mention the Union joint on the steering column aswell but yet to get my mechanic to have a look at that.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Have you checked alternator and battery are working properly
    Nov 2009
    newcastle
    Sounds extreemly daft but have you checked the fluid reservoir?
    After that as above high chance electric, when it happens does the vent fan speed drop?
    The car has a life support system for loss off electrics and fans are pretty much 1st thing to be cut off by the ecu to preserve priority bits like steering, engine etc
    May 2014
    Liverpool
    11 Post(s)
    Trim : SRI
    Yeah checked the reservoir straight away it was a little low but nothing to bad, I topped it up and since checked a couple of times and the levels not changed. I had the blowers on this morning and trying to check but it literally lasts for a second or 2 but doesn't seem like it is stopping the fans from working. I'm going to change the top mounts and bearings and the UJ when I'm home
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Check the electrical plug/sockets on the pump as well - the securing clips on the large connection can easily be damaged and allow plug to become loose and give you a momentary loss of power to the pump - Mine did and the contacts were pitted and burnt where it had been a poor connection
    Nov 2009
    newcastle
    If fans are not cutting In my mind puts blame towards motor or connections themselves.
    Remove plugs n clean up.
    It will be either due to motor using more power than can get, or check if only happens on stronger corners as weight shift and happening could be a lose contact somewhere
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    This only happen on sweeping bends? Both directions, or just one?
    I ask as it sounds like a lower bush on the lower arm could be worn, those will cause this kind of 'drifting' on sweeping bends and depending on the type you fitted 7 months ago, this could be on its way out again.
    May 2014
    Liverpool
    11 Post(s)
    Trim : SRI
    It's hard to explain the problem via text, it will happen most times when starting to turn, for a second or 2 the steering is heavy then all of a sudden "releases" and goes normal.
    I had the lower arm that was fitted 7 months ago checked as I changed the other side, my mechanic said it was fine and not in need of changing but I'm obviously only taking his opinion on that.
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    19 Post(s)
    Trim : Exclusiv
    Did your mechanic mention the possibility of an air pocket in the power steering system?
    May 2014
    Liverpool
    11 Post(s)
    Trim : SRI
    Had the fluid in the system changed, came out grey, as soon as he put the fresh fluid back in that instantly changed grey too.... I've sourced a rack and pump so just going to get that all changed for piece of mind.
    Sent from my iPhone using Tapatalk
  1. heavy steering
    By lh_4827 in forum Suspension, Wheels & Brakes
    Last Post: 2nd March 2013, 17:38
  2. very heavy steering
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 19:10
  3. 1.9 Momentarily Cutting Out
    By Homer in forum Engine & Drivetrain
    Last Post: 17th June 2012, 10:07
  4. Steering is a little heavy and juddery
    By freshprince in forum Suspension, Wheels & Brakes
    Last Post: 21st August 2008, 11:57
  5. Steering heavy HELP !
    By cpt slow in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2006, 09:03
vectra c stiff steering
Opel signum steering wheel problems
astra 1.9 cdti stiff steering wheel
how to replace steering rack on vectra 2007 cdti
Vauxhall vectra c steering going stiff
vectra c power steering pump contactszafira steering sometimes stiffvectra 1.9cdti power steering noisesteering system tight on vectra cvectra c steering racksteering feels stiff sometimes on vauxhall vivarosteering rack joint vauxhall vectravauxhall vectra 2008 power steering really stiffvectra c notchy steeringsteering heavy foot on brake turning power steering vectra cvectra c steering goes heavynotchy steering astra hvauxhall movano power steering goes heavycommon cause of heavy steering on vectra cdtivauxhall vectra c heavy steeringVectra cdti steering heavy when turning rightstiff steering vauxhall vectravauxhall.vectra design. steering heavy2006 vauxhall vectra 1.8 lumpy steering wheelvectra steering heavy
