any tips on changing headlight bulbs,,,shreaded my hands trying
It is a bit of a task to change the dipped ones, but the sidelight and main beam are worse. Well nearly, just the drivers side you have to get past the airintake pipe I found it better to remove it, you don,t cut your hands to bits though.
yeah dont i no it,,going to have to wait a few days until the wounds heel
sometimes it's easier to take the bumper off and take the lamps out..
o my god that sounds like surgery,,,is this something the dealers can do
being a bricky i would probably rip the front end off,,,or lose my temper and just drive it into a wall and claim on insurance,,will get done that way
the alternative is to remove the airbox on the driverside.. not a big job, but gives you loads of access ( just take the lid off and pull the base up,, it's on studs) and take the windscreen washer filler tube out of the passengers side ( prise up the clip off the slam panel and then just pull it up out of the seal..
if i can get in with my 'shovels' of hands then you can do it too....but it does get 'cosy' inside the lamps..
tried today,,gave up,,the mrs just said why did i struggle, she would have done it,,skinney hands
...ask her if she will sort it for you..
