Thread: Cruise control stalk replacement
    Regular Member mickeyc's Avatar
    Over there between the land and the sky!
    Default Cruise control stalk replacement
    Just bought an indicator stalk off ebay for a fiver on the basis that my cruise isn't working and I thought it would be a cheap way to find out if its the switch.
    Anoyone got any ideas as to how I take the old one off and put the new one in?
    i beleive it just pulls out.....
    nope, i was wrong....
    just been out to my car and had it apart......take the column shrouds off to get in to it, don't forget the 2 screws hidden behind the arc of the wheel under 2 little covers..
    are you sure it's the switch?.. its usually the clutch pedal switch that gives the fault..
    Nope but at the cost of only a fiver compared with what vx would charge (£30ish?) I thought it was worth the risk. Agreed its more likely to be the clutch pedal switch but thought I'd try the easiest option first. £5 isnt a lot to loose.
    true, but you can prove the switch without fitting a new one, if the stalk doesn't work..
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Just drive while holding the clutch pedal up with your foot, then try CC. Its usually the clutch spring so holding it up will do the job of the broke/weak spring.
    exactly..
  1. Cruise control stalk
    By chrisvectra in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2013, 01:15
  2. Cruise Control Stalk
    Last Post: 27th April 2011, 12:51
  3. cruise control stalk
    By n8sby in forum Parts for sale
    Last Post: 25th May 2010, 11:48
  4. cruise control stalk
    By AL21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2008, 16:14
