Results 1 to 10 of 16
Thread: Tyres
    Apr 2006
    Quinton
    Default Tyres
    Hi,
    Am i ok to run 225/45/17's on my 17" pre facelift sri alloys??
    If so do i need to change all four at same time or could i do an axle at a time??
    Thanks for any advice
    Nick
    they are okay on width for the rims, but 45's will affect the accuracy of the speedo readings..they will be 1.9% out, so when the speedo displys 60mph you will in fact be doing 58.8mph... all perfectly legal as you have a 10% tolerance..
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    Yep, all okay I think. The facelift manual even quotes tyre pressures on 17" alloys for 215/50 and 225/45, so they must be okay I guess.
    And AFAIK you can just change 1 axle at a time, but not sure if there's a specific order you should do them (e.g. new, wider tyres at the rear). That would make sense I think, so if you're getting them for the front get the fitters to swap your rears for your fronts perhaps (other's will have done this and know more).
    Apr 2006
    Quinton
    thanks for the info - the speedo could do with pulling back a bit tbh. It appears to be using it's full 10% tolerance at present i.e. when sat nav says 70 - speedo reads 77ish.
    Any more thoughts on changing 1 axle though? Will this affect stability having different profiles?
    Most of my miles are done on country roads - 120miles a day round trip to work :-(
    changing one axle will have no bad affects to your car, it's quite normal practice..
    Regular Member wardy's Avatar
    Chichester
    Quote Originally Posted by Nickzx6r View Post
    I did this, putting the 225s on the back without any problems.
    No they don't, the EU conformity for the Vectra C is based on the 205/55R16, the 225/45R17 is closer than the 215/50R17
    VX chose the 215/50R17 as it looks better on the wheel, when matched to the car
    I had this checked by VOSA on Saturday morning after the new tyres were fitted
    215/50R17
    Indicated 40mph = calibrated 39.2mph
    225/45R17
    Indicated 40mph = calibrated 38.6mph
    Quote Originally Posted by um20 View Post
    I am in the process of changing from Good Year NCT5 XL 215/50R17 95W 240/A/A to Good Year F1 GSD3 XL 225/45ZR17 94W 280/AA/A
    The GSD3 has a narrower footprint on the road, and this can make the back end a bit twitchy on high speed cornering
    The treadwear rating on the GSD3 is also 16% higher, so should last longer
    The 225/45R17 also looks skinnier than the 215/50R17 when fitted to the car
    I swap wheels rear to front at they wear, the NCT5 wore out this week, so the GSD3 went on to the rear on Saturday morning
    The fitter I used asked if I was sure, as their listing doesn't show the 225/45R17 for any of the Vectra C, but I showed him the manual and my calculations from the EU Conformity
    "Blimey, you've done your homework on these, let us know how they go, as they are £50 cheaper each!"
    From the limited road testing I carried out yesterday, the road noise is also much less, the rear of my car is much quieter now
    I will also take a photo of the wheels shortly so that you can compare how the wheels look with the 215/50R17 and the 225/45R17
    right, well i hear what you're saying, but the figures i've given come from the tyre size calculator listed on this site..
    http://www.miata.net/garage/tirecalc.html
    You need to compare both tyres against the 205/55R16, that is what the speedo is calibrated for
    Recheck on the tyre size calculator
    As you will see the 215/50R17 is way out!
    215/50R17
    225/45R17
    christ you need to get out more!
  3. More tyres....!
