Results 1 to 10 of 16
Thread: Yellow looking Sidelights
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Default Yellow looking Sidelights
    Hi Guys
    Don't know about you but my sidelights look pretty rubbish next to all the other bulbs up front (when on that is). Can anyone recommend a W5W replacement bulb that doesn't suffer with this yellow look.
    Cheers!
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    Hi, PIAA do some really bright ones, although a bit pricey. i have tried the phillips blue vision ones but they seem to loose the colour and go burnt looking after a short while.
    Best results i have seen are the LED type but you have to wire in a resistor or the fault light will come up on your dash!
    Woodsta
    Regular Member Ralph wiggum's Avatar
    Oct 2006
    Bexleyheath, Kent
    I've got the PIAA Extreme white side lights in Mine along with PIAA Plasma Blue Headlight lamps..... The H7 Lamps are quite pricey, but the side light bulbs aren't too bad on E-bay
    May 2006
    Kent
    Feb 2007
    The pool
    Well have ordered some new PIAA side lights..
    Decided to go with the Platimum White range and @ £10.99 not the cheapest but there you go......
    This however is the result, STUNNING...........
    First one is side light only, 2nd with dipped
    Regular Member ACE.TAG's Avatar
    Feb 2007
    hamilton
    If i changed the side light bulbs in my new facelift veccy will that cause warning lights to come on or will it be ok??
    Feb 2007
    The pool
    Mine IS a facelift vectra - I think the only time you'll get probelms is when trying to use LRD's
    The link to the place I got min PIAA's from is here
    Feb 2007
    The pool
    Not many have looked at this thread since piccies added. Would have though most would upgrade their lights and want to see results.
    With the performance of the PIAA side lights I am tempted to upgrade the dipped to PIAA as well but @ £40 odd for a set of H7's it might have to wait!!
    Feb 2007
    hamilton
    Quote Originally Posted by 2.2 Direct SRi View Post
    But that link says that there leds so what are lrds then
    Are these the same as those PIAA ones that you put the link up for?
    http://cgi.ebay.co.uk/Side-Parking-L...QQcmdZViewItem
    Regular Member stickshift's Avatar
    North London
    Sorry to steal your thunder but this thread might be why.
    http://www.vectra-c.com/forum/showth...highlight=PIAA
  1. None LED sidelights
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 02:34
  2. led sidelights
    By neverlandandy in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2011, 22:47
  3. found this Yellow vectra c? did they make a yellow one?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 02:50
  4. Yellow at last....
    By bobby-tupper in forum Quick Photo Album
    Last Post: 6th April 2009, 07:43
  5. should i go yellow....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 22:06
