Thread: Help!!!!!!
    Regular Member Petrolhead's Avatar
    Mar 2007
    Sheffield
    Default Help!!!!!!
    I've just been for a spin in my vecky and the computer display has just lit up with "check your rear right brake light". I have checked it and found nothing wrong, the bulb and the the connections are ok!!!. anyone got any ideas.
    Mine used to do that a lot, check this, check that, think it was just having a laugh, if the brake light is still ok the check should dissapear again ..
    check all the other bulb fittings as well, it'll only take a small fault in the bulbs connection to upset the light check system.. so it's time to clean and check all the bulbs..
    Mar 2007
    Sheffield
    Cheers, will do
    Regular Member danlat1415's Avatar
    Lancashire
    Try taking out the bulb, and putting it in the opposite light. If it disapears, and says check the left side, then you know it's the bulb.
    Mar 2007
    Sheffield
    I hate smart people, i'll try that LOL!!
