Results 1 to 10 of 24
Thread: Loss of water 2.0 Dti
    Regular Member gipps's Avatar
    maidenhead
    confused Loss of water 2.0 Dti
    Can anyone help me......52 plate 2.0 Dti.......I lose a lot of water from the expantion tank. If i am just plodding around from a-b then perfect but as soon as i go on the motorway and give it a bit of welly it starts to dissapear....I have changed the cap today as a start but it still losses it. Cannot see any apparent leaks anywhere and its not overheating....
    Any ideas?
    manual or automatic?..any trace of oil contamination?..no leaks when idling stationary and the engine is hot?..
    maidenhead
    Manual...........no contamination and no leaks when idleing hot,thats whats confusing me!!!!!!!!
    well the water is only going one or two places, so it's either leaking out of a gasket joint or a pinhole in a hose, or else it's going out of the exhaust...no other ideas on where it's going?????
    maidenhead
    Thumbs up
    Ok thanks for that..Just phonead a friend of mine who's going to pressure test it for me 2moz,so hopefully i'll find out more then.............
    Thanks for the help
    it'll be the best way to find out where it's going.. if he's got a diesel adaptor for a cylinder leakage test it will also tell you more..
    maidenhead
    Ok thanks..I'll let you know how i go.............
    maidenhead
    Angry
    Been to the local stealers.............
    Had pressure test,had car running for 4 hours,had mechanics scratching there heads for another 4 hours. No leaks,no condensation from exhaust,no clue!!!!!!!!!
    They said air lock,so they bled system,they said expansion tank,so they replaced it,they bled it again,they said not head gasket,not water pump,not rad...................I came back to a nice £238.57 parts and labour bill.........Then they said they have NO IDEA ......Don't go to A.A.Clark in Windsor cos they are useless..... They are trained mech's that work for a vauxhall dealership but can't fix a car (NO WONDER THEY ARE SHUTTING DOWN IN 2 WEEKS)
    Does anyone know a good Vaux mech near Maidenhead?
    Mar 2007
    yorkshire
    Question
    Any oil droplets or sludge appearing in expansion tank floating on surface when you top up water level?
    Was it a radiator pressure test, or was it a block test?..big difference in what it can tell you
  1. Water Loss CDTi 150
    By GCM in forum Engine & Drivetrain
    Last Post: 19th November 2013, 12:07
  2. Water Loss on Vectra 1.9CTDi
    By bray in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2012, 12:58
  3. Could be big could be little, Its water loss.
    By Mawbs in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 18:14
vauxhall vectra 2.dti losing water
Vectra c 2.2dti expansion tank
