Thread: How to replace front wheel bearings
    Mar 2007
    England
    Default How to replace front wheel bearings
    Does any one have any info on how to replace the front wheel bearings on a Vec-C? Tools required? etc
    you'll need a socket big enough to undo the main bearing nut on the driveshaft and torx bits to undo the bottom balljoint pinch bolt. you'll also need torx sockets to undo the 3 bolts that hold the bearing assy to the hub frame..
    undo the bearing nut before raising the car if you can as it's tight..
    raise and support the car and remove the roadwheel...remove the brake caliper and support it so it doesn't hang on the hose.. remove the caliper carrier and disc..undo the lower balljoint crossbolt and seperate the balljoint from the hub, slide the driveshaft out of the housing.. disconnect the ABS lead coming from the hub..Now, undo the 3 bolts that hold the hub to the upright. clean the mating faces and refit the new bearing to the hub.. then rebuild..
    Dec 2005
    In the sponge-monkey tent
    You make it sound so easy!
    Meccano for BIG kids..:...
    Feb 2006
    Guttedsville
    He did three in between washing Cara's car earlier!!
    Mar 2007
    England
    Cheers GSi (Once again!!) Do you know what size torx I need? I don't have any so would prefer not to buy a whole set just to use two!!
    Also do you know any of the torque settings when putting back together, especially the hub nut? Or is it just a case of doing it FT??!
    it's not on the tip of my tounge mate, if thats what you mean....but i'll do some homework for you if you like..these fixings will be tight, so buy the best quality you can afford..
    Mar 2007
    England
    Cheers mate, I'd appreciate any details you can find out. I can't believe you don't know off hand, I'd always thought you were the Yoda of Vectra-C!!!! Replacement of bearing, you are!
    Alex
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by Aleco View Post
    "Hmmm......Mark GSI...Help you he will.."
  1. front wheel bearings!
    By jimbo1987 in forum Suspension, Wheels & Brakes
    Last Post: 26th March 2012, 15:45
  2. does anyone have a how2 for front wheel bearings
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2011, 20:22
  3. Front Wheel Bearings
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2009, 20:00
  4. GSi front wheel bearings
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 17:38
  5. Think my front wheel bearings have gone
    By vectravirg in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2008, 19:12
vectra c wheel bearing
vectra c front wheel bearing
wheel bearing vectra c
vectra c front wheel bearing change
vectra c front wheel bearing replacement
vectra c wheel bearing bolt torque
how to change a wheel bearing on a vauxhall vectra
vectra c front wheel hub
vectra c front hub
vectra c wheel bearing replacement
vauxhall vectra c front wheel bearing
how to change a front wheel bearing on Vauxhall vectra
how to replace front wheel bearing on 57 vectra c 1.9 cdti
vectra wheel bearingchange front wheel bearing vauxhall vectra cvectra c how to diagnose wheel bearingvectra c changing hubvectra c wheel bearing fittingVectra wheel hub replaceVectra wheel hubwheel bearing vectra c frontlateral movement front wheel Vectra cremove vauxhall vectra wheel bearingshow to change vauxhall insignia front wheel bearinghow to change front wheel bearing on vectra c
