Thread: Back window washer not working...
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Back window washer not working...
    Anyone had this problem. I tried to use the rear window washer. The pump is working and yes I have filled the washer reservoir but hey guess what no water coming out of the nossle.
    Any ideas how I can sort this myself....
    Regular Member Harry's Avatar
    Uxbridge, London
    happened to me, same problem. you can hear the motor whizzing so you know that's working. it's a common problem....the feed at the bottom of the water tank gets blocked. apparently it's easy to locate and fix the problem, luckily enough, mine went by itself. in order to clear the blockage you need to remove the tube or something at the bottom of the reservois.
    Mark (GSi3.2) will be able to tell you exactly what needs to be done.
    remove the screws on the drivers side inner wing where it meets the bumper..this will let you peel the inner sheild out of the way so you can get to the motor..prise the motor straight up out of the reservior and remove the black seal, water should flood out...
    now clean the seal under a tap until water shoots out of it through all the fine holes in the sides and end of it..then just replace the seal and the motor into the bottle, refill and test.. if it all goes fine then refit the screws..... 15 minute job..
    the cause is sludge formed by screenwash concentrate....it shouldn't happen again now the tank's been emptied..
    if the fronts work and the back doesn't , and the headliner inside the car isn't wet, then look at the valves on the motor..
    Mar 2007
    NI
    Many thanks lads.... Looks like another one of those Sunday jobs... at least the weather is on the upside....
  1. washer jets -NOT WORKING!
    By nim-nim in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2011, 18:52
  2. Washer Not Working
    By Hollingsworth87 in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2011, 15:15
  3. window washer jets not working
    By steve-wolves in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 13:43
  4. Help, the back ligth and back door not working after using hanger
    By joacom in forum Vectra C / Signum Troubleshooting
    Last Post: 19th April 2009, 15:24
  5. window washer not working
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2009, 15:29
