Results 1 to 10 of 13
Thread: New brakes rubbing
    Mar 2007
    Devon
    confused New brakes rubbing
    Hi,
    My 02 Vectra C 1.8 Club is in a VX garage getting new brakes but they can't make them stop rubbing. They have put two new sets on now and can't work it out. They are asking VX if the size of the brakes has changed since 02 but this seems unlikely to me.
    Has anyone ever experianced issues of brakes not fitting or rubbing?
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    where do they rub?
    Bristol
    When you say 'rubbing' do you mean all of the time or just when braking similar to the brakes binding, a bit like a drone?
    Sticking caliper slides?..or pistons not fully retracting.. i've never had a set of VX genuine pads that won't go straight on..
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    got a constant drone from the rear brakes on my motor, and been told that its cos its disks all-round and its like it on all vecs...
    Midlands Mod Shop - NFFC.
    erm...nope.....i've never had one that constantly drones...
    they do suffer from noisy pads grinding when you stop, but thats down to low asbestos fricton materials..
    Belfast
    Quote Originally Posted by ditchp View Post
    Your dealer is telling you little fairy tales. Remember, first thing an apprentice mechanic is taught (after the location of the kettle), is to say "They all do that" in answer to any question.
    Trim : Get a
    originaly i thought it was a wheel bearing as that is what it sounds like a realy dull droning noise
    i'd go with bearing if it's a speed related droning noise, or look at the tyres..
    if you take the wheel off and turn the hub by hand, does it feel gravelly??... brakes don't drone, they will'grind' on application or 'ring' if the antivibration backer isn't doing it's job..
    Mar 2007
    Devon
    confused Top posting
    Hi,
    They changed the brakes once but when i went to work in the morning it felt like the car was really slugish. The brakes were kind of on all the time and getting really hot!
    They changed the brakes again full set but the same happened again?
    Still not got it back, so stuck with a Corsa for now and i don't fit in it .
    Has anyone ever herd of brakes getting stuck on? thats what i meant by rubbing.
  1. Rubbing noise nsr
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2011, 01:05
  2. Rubbing down plastic
    By Das in forum Bodywork & Interior
    Last Post: 22nd October 2010, 10:02
  3. rubbing strips
    By chewy71 in forum Bodywork & Interior
    Last Post: 1st October 2010, 11:32
  4. rubbing noise?
    By Messenger in forum Engine & Drivetrain
    Last Post: 24th February 2009, 21:21
  5. Rubbing noise
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 23:56
