Thread: Radio won't turn on without display?
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    Default Radio won't turn on without display?
    I took the display out from between the air vents earlier (thanks for the how to rushy!) to see how i was going to go about fitting a photo frame.. I've now found that the radio doesn't turn on without the display being connected! It's an aftermarket radio... anyone know why this is and how i could stop it happening?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i think im right in saying ..but might be proved wrong .....lol........if you remove / discontect the display the engine wont start as it is one of the enviromant identifiers ........... for the immobo system ..... it is a major link in the can bus system on the early cars ...radio on the later one's .....i would say it has too be fitted ....but there may be a way around it but im not to shure how ............
    Mar 2007
    Wigan & Preston
    The engine still starts, just can't turn my radio on! lol
    I've got the 2 line display which only shows the time and temperature (and date if the radio is off). I'm hoping to replace it..
    Perhaps i could try to remove the actual screen but keep the PCB connected behind the photo frame i'm hoping to put in.
    Feb 2006
    dudley
    it must tell the body control to feed the radio .....all you need is to check the voltage from the bcm (at the radio plug) when fitted and when not and rig your own feed ...
    Mar 2007
    Wigan & Preston
    I need something to hold the new display in place. the old one might just do the trick! lol
  1. Turn off auto radio?
    By Rab in forum Vectra C / Signum Troubleshooting
    Last Post: 26th January 2014, 19:27
  2. My Radio Will Not Turn Off CD30
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2011, 00:25
  3. display wont turn off
    By Sauce in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 19:40
  4. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  5. can i turn display off?
    By scottie in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2006, 20:49
