Thread: Fitting 4cd in dash
    Oct 2006
    Leeds
    Default Fitting 4cd in dash
    Hi
    I'm refitting the original 4CD in dash head unit. I've plugged it all in but it says 'safe' on the display - i assume i need the keycode. Anyone know where the best place to look is?
    Also, I can't get the head unit all the way in, its meeting some resistance with about a cm to go. Any tips?
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    if ure after a key code for it, mine was on/in my radio booklet i got with the car (along with the service manual etc.).
    Oct 2006
    Leeds
    Yeah can only find a 'keycode' though - accoring to the booklet this is for programming the keys.
    Vauxhall have said i need the 'security code' and i can't find this anywhere.
    By the way, I was told to hold 'AS' down, turn the radio on and then i could enter my code, but it didn't work - stil said 'safe'.
    oh right, i thought the keycode was the security code. lol.
    i cant remember how to enter any codes etc, years since i had to do that. sorry.
    Regular Member jamesr's Avatar
    Lancashire
    If the display shows "SAFE".
    1.Switch on ignition
    2.Switch off the radio
    3.press and HOLD AS
    4.Swich on the stereo, and keep AS pressed until you here a beep.
    5.Key in your keycode using key presses.
    Ie 0356
    Press key 1- once
    Then key 2 - 4 times
    key 3 -6 times
    key 4 - 7 times
    once the correct code is shown on the display - press AS again
    EASY!!
    cambridgeshire
    My code was on the little card (credit card size) that is in the owners handbook wallet thingy. New head unit this weekend so bye bye in dash changer hello Alpine.
    Lancashire
    IBarfoot you have PM
    Quote Originally Posted by grunners View Post
    if you didn't get the 'car pass' with the car, with the code on it, you can apply to VX to get another one..they will charge you thou..
    Jul 2006
    About not being able to push it the last little bit....
    I have the same problem sometimes, too - turned out to be the wiring loom getting snagged behind the HU as it goes into the cage.
    HTH
  1. Facelift Dash Trim on a Pre face dash?
    By jordib in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 22:15
  2. Wiring - Dash loom/cables behind whole Dash
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2013, 10:49
  3. Fitting a TomTom XXL into centre dash
    By James2k in forum Electrical & ICE (including SatNav)
    Last Post: 29th February 2012, 16:20
  4. Dash on, dash off Daniel Son.
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2011, 18:38
vectra c 4cd unit
