Thread: Removing Scratches from wing top
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    Default Removing Scratches from wing top
    Advice please.
    I've gained some very fine scratches all along the passenger side wing (caused by having to pull into a hedge to get passed a tractor.
    What's the best/easiest way to remove them that doesn't cost the earth.
    I use AutoGlym range for car care.
    Regular Member blr123's Avatar
    Dundee, scotland
    Hi Richard,
    The best product from the AG range is SRP, just apply using an applicator pad with a bit of pressure and that should do the trick you might have to do a second application but if it's just the top of one wing then 10 to 15 minutes is all it should take........then give it a lighter application and then top with EGP job done
    Bryan
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    have a look at 'scratch x' from meguires its gooood
    Midlands Mod Shop - NFFC.
    Dundee, scotland
    Scratch X is definately the way to go.......I was just sticking to the AG that Richard said he had and SRP will help a lot and it's packed with fillers so anything that is left wil be filled
    When applying Scratch X do it in straight lines i.e. the length of the car then accross and only work on an area about 12" x 18" or no more than 18" x 18"!!
    Bryan
    Jan 2006
    Oswestry
    Thanks useful advice as always
  1. Swirls and scratches
    By Max Payne in forum Detailing and Car Care Discussion
    Last Post: 25th September 2012, 15:33
  2. Removing light scratches from glass
    By Steveocee in forum Detailing and Car Care Discussion
    Last Post: 10th September 2011, 07:34
  3. Removing Wing Mirror Glass
    By Das in forum Bodywork & Interior
    Last Post: 29th July 2010, 10:50
  4. Removing scratches from piano black trim
    By James24 in forum Detailing and Car Care Discussion
    Last Post: 6th May 2009, 21:35
  5. Scratches
    By Matt21385 in forum Detailing and Car Care Discussion
    Last Post: 8th June 2006, 16:57
