Thread: Tyre Help
    LEEDS
    Default Tyre Help
    Hello, my front and back tryes are pretty ****ged at the moment - backs on their way out but have a few thousand miles left in em but fronts are bald!
    I read on here that you can change from 215/50/17 to 225/45/17 as they are a lot cheaper.
    Would I be able to run 225's at the front and 215's at the rear or would I have to swap backs for fronts?
    Thanks a lot.
    Regular Member wardy's Avatar
    Chichester
    what I did was put the new 225s on the back and stick the old part worn 215s on the front. That way they'll scrub out quicker & you can then change them to 225s as well and end up with all 4 the same sooner.
    I think it would be ok, they always recommend fitting new tyres to the rear to reduce the chance of oversteer in an emergency. Apparently under steer is easier to control!
    As long as they are on the same axle, I can't see a problem
    Jul 2006
    No problem at all.
    LEEDS
    thanks fella's.
  1. Tyre help
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2011, 01:12
  2. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  3. Which tyre??????
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 09:49
  4. 215/50/17 tyre
    By jonnye in forum Parts for sale
    Last Post: 14th September 2006, 22:08
