Thread: Fitting a Parrot to a CD70navi
    Default Fitting a Parrot to a CD70navi
    Is there a cable for it, as the only ones I've found state they wont work with the CD70?!?!
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Which model Parrot Jamie?
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Of all the quad loack leads I've fitted to Vectras none of them ditinguish between model numbers of stereos they will or will not work with.
    With the nav unit you will need the two smaller plugs of the quad lock continued from one end of the converter lead to the other.
    You'll see in this converter all you have is the power & audio leads which go through the Parrots harness but the two smaller plugs I am talking about are not there. You can unclip these plugs from the OE plug reinsert them in the plug which plugs into the radio.
    I can supply you the two pins needed to push into the audio input part of the plug then all you need to connect up is the power. This way you don't have masses of converter leads to stash away behind the dash.
    That sounds like a good solution to me Ben, I'm a little confused but I think you're telling me I only need a couple of pins, rather than a whole converter loom.... so what exactly would I need to do a proffessional job of installing a Parrot 3200LS and how much can you supply the parts for??
  1. Fitting Parrot In vectra Help
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2011, 18:31
  2. Help Fitting Parrot Handsfree
    Last Post: 24th October 2010, 14:50
  3. DIY Parrot fitting.... Pre face
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2010, 10:59
  4. parrot fitting
    By lochgilp in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2007, 10:38
  5. Parrot CK3100 Fitting?
    By In a states in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2006, 16:00
