Thanks Thanks:  5
Likes Likes:  20
Thread: Woody's Vx/Opel ICE - Home of the Comfort Unit and Accessories from www.PepaS.cz
    May 2012
    North West (Warrington)
    211 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Default Woody's Vx/Opel ICE - Home of the Comfort Unit and Accessories from www.PepaS.cz
    I am delighted to be the UK / Eire distributor for the Comfort Unit and related Modules. These are a group of products that are designed to enhance and provide additional information on the range of Opel / Vauxhall CANBus factory-fitted head units – CD30, CD30 MP3, CDC40 OPERA, CD50 PHONE, CD70 Navi or DVD90 Navi, Touch & Connect infotainment units or other unoriginal units, and with steering wheel remote controls (Scroller type NOT Button type).
    Applicable vehicles are Vectra-C / Signum / Astra H / Zafira B
    These Comfort Unit & Complimentary Video Units were designed and manufactured from the outset by Josef at www.PepaS.cz
    This designer / manufacturer has spent many years of code dis-assembly and understanding of the original OEM instruction sets built into these GM headunits and displays. From there he has produced some highly desirable modules, which once fitted, will almost certainly leave you feeling as though they were built to be there from the outset by GM and their Suppliers.
    Comfort Unit - Adding a Comfort Unit to your compatable Headunit & Display, (it simply plugs into the OBD Diagnostic port under the ashtray) will allow you to view Additional Diagnostic Information, Monitor DPF (Diesels with DPF), Boost (Turbo Engines Only), and Aircon Pressure (ECC Units only) “See” a Parking Sensor Display of what your Factory Parking Sensors are “seeing”, view digital readings for Speed & Temperature, Add Coming Home Lights and VXR style Dial / Needle Sweep and Startup Dial Lights to the dashboard and also add an OverSpeed Warning Beep. If you have a VXR engine, then even more features for monitoring performance are available.
    Video Modules – Adding a Reversing Camera and Video Aux In / Alternate Video to a CID Colour Display - With a Comfort Unit already in place, adding fully menu driven Video is as simple as connecting a VCU-01 module (or a VCU-02 if you do not require a Comfort Unit as well) and then you can make use of video options such as a Reversing Camera, or Multimedia (if you have auxilliary sound already) if your vehicle has a Colour Display Screens (CID). When video is connected via this arrangement, all original screen warnings related to the operation of the vehicle will still function as intended unlike some other products on the market.
    The Comfort Unit - CU
    CU + VCU-01 User Guide:
    Zafira-B OCU-ZB-IK installation Guide (using mounting bracket)
    The Video Converter Unit - VCU-01
    Adding Video Aux Input to your Vauxhall / Opel Colour Screen
    Demo Videos
    VCU-01 Installation Guide:
    The Video Converter Unit - VCU-02
    Demo Video:
    VCU-02 Installation Guide:
    Power Supply Module RASP-PSM + Case for the SBC Raspberry Pi
    Power Supply Module RASP-PSM + Case for the New SBC Raspberry Pi 2
    Camera Power Switch – CAM-PS / Reversing Camera for OPEL/Vauxhall - CVBS NTSC video output
    Wireless RC for the Raspberry Pi
    OPEL Insignia/Meriva-B AUX/USB/SD-card slot for the Raspberry Pi
    Part Number - 13363146, part code 1787032
    NEW 3.8di - For Vxr / OPC Engines - The Very Latest Comfort Unit Firmware version 3.8di is now available - The update adds ECM data for Z28NET, Z28NEL, Z28NEH, Z20LEX and Z20NET engines as well as Full Needle Sweep for non Vxr's and Coming Home Lighting.
    The FIRMWARE Change Log Summary as follows :-
    MFD-CAN_2.9e – added UK Imperial units support
    MFD-CAN_3.0e – added Z13DTH ECM support
    MFD-CAN_3.1e – added #3 (RGB+S) video input support on the VCU-01 & installation without CD70/DVD90Navi
    MFD-CAN_3.4e – added configuration and DPF data is saved to the FLASH memory of the microprocessor in the CU to EEPROM, acoustic overspeed warning function, digital speedometer on the display function, modified function "Alert on engine heated up", amended - if "Alert on engine heated up" & " Close msg. box manually" configuration items are active and coolant temperature is less than 80 degrees Celsius then coolant temperature is automatically displayed on the GID/CID (if "On Info-Display" is selected) or on the IPC (if "On Info-Display" is selected). In this mode, the coolant temperature displaying is automatically deactivated when the temperature reaches 80 degrees Celsius.
    MFD-CAN _3.6di - Catering specifically for Vectra 2.8 Vxr/OPC owners. The update added ECM data for Z28NET, Z28NEL, Z28NEH engines.
    MFD-CAN_3.7di – Added the other Vxr/OPC model engine specific cars with Z20LEx and Z20NET engines.
    MFD-CAN_3.8di - Adds the VXR/OPC Needle Sweep & Full Instrument Panel Light illumination at startup and a new Coming Home Light option
    Here are youtube video demos of the new features in action -
    Latest - Vxr/OPC Software Update 3.8di
    Z28NEX & Z20LEX ECM Monitor - User guide:
    Follow Me Home Lighting (Video courtesy of HarrysDad)
    I just thought I would wet the appetites of those existing members who have already purchased a Comfort Unit
    Here's an example of a recent enthusiasts installation of a Video Unit (VCU-01) to which he has connected a DVB-T Digital Television Receiver, together with a Raspberry Pi to play his Audio and Video Media Files, and obviously he has a reversing camera hooked up too
    The Headunit is a DVD90 (he is a Polish lad living and working in Bristol).
    PRICING
    Comfort Unit - £120 + Carriage £7.50 via Royal Mail Tracked 24 next day
    VCU-01 & VCU-02 - £180 + Carriage £7.50 delivery 1-2 weeks
    CAM-PS - Camera Power Switch - £25 + Carriage £7.50 delivery 1-2 weeks
    RaspberryPi 2 - £120
    This is for the RaspberryPi 2 complete, fitted with 12v Regulated Automotive PSU and Case, together with 8gb microSD together with Openelec OS with KODI (formerly XBMC) and media licenses for Audio & Video. (At this time I will not be supplying the Pi 3 which has integrated wifi and bluetooth. This is because these are fitted "onboard", and it is anticipated that users would need to disable these devices and fit external USB alternatives due to the Pi being fitted inside a screened Automotive case).
    Wiring - For anyone who is "fazed" by the thought of "wiring", I can also supply a set of prewired "plugs with 12" tails" for the Video Module VCU-01/02 , CAM-PS (Camera Power Switch), and Raspberry Pi2 case - £10
    RGB Cable Modification with a VCU-01 or VCU-02 Video module - For the more daunting task of modifying the RGB cable, then I can point you in the direction of a friend of mine who is experienced in fine wiring and who will modify your cable for you - £35 using the plugs supplied including postage.
    Payment - Via Paypal - Please Cover Fees
    I am also able to offer an AUX In Retrofitting Service for the CD70 & DVD90 Headunits
    with a special price for forum members and carried out on my behalf by PepaS.
    CD70/DVD90 Aux In Retrofitting - The cost of this (Priced in Euros) including all parts, fitting, and firmware update is 50 Euros + Return via UPS a further 23 Euros
    So approx £56 (as at 5/6/2017) all in.
    Other Services
    As a further part of the service offered via my arrangements with PepaS, I am showing the costs/charges for Firmware Updates and Security Code Retrieval of the headunit and display modules associated with this range of vehicles.
    All charges / costs for this work are shown in EUROS (€).
    Please note that no soldering or dismantling of the equipment / modules is carried out during the update/upgrade process.
    The cost of Return Transport via UPS will need to be added to the charges shown. This is typically €23 and return delivery to UK usually takes 5 working days.
    GID / CID Firmware Updates - 2 to 3 line Display conversions
    Astra-H, Zafira-B GID firmware update: firmware version GD55/GD59
    (2-lines BC) -> GD83 (3-lines BC) - €40 + Postage
    Astra-H, Zafira-B CID firmware update: firmware version CD55/CD59
    (2-lines BC) -> CD83 (3-lines BC and OPC/VXR startup logo) €40 + Postage
    Vectra-C / Signum CID firmware update: firmware version CE55/CE59
    (2-lines BC) -> CE83 (3-lines BC and OPC/VXR startup logo) €40 + Postage
    Astra-H, Zafira-B, Vectra-C / Signum GID/CID Security Code Reading or Resetting €20 + Postage
    CD70Navi, DVD90Navi security code reading or resetting - €40 + Postage
    Please be aware that converting a display from 2 to 3 lines should only be undertaken for modules already paired and working in your car. It will also mean that you will lose the "miles remaining and navigate to nearest "Petrol station" option.
    The new CID/GID display (GE83, GD83, CE83, CD83) can not be used in older cars (2005/06) in some rare cases. There is problem in measuring the amount of fuel in the tank; the exact cause is unknown. The CID/GID must be firstly correctly configured in the car and then firmware update can be done. This pairing and configuration procedure must be guaranteed to have been carried out before modification otherwise there will be a problem with fuel measurements.
    Once modified, if the range is less than 50 km then range is not displayed in the 3-line main window and the option to navigate to the nearest petrol station will "disappear".
    For the security code reading of the CID/GID service with a paired set of headunit / display modules, only the smaller and lighter of the 2 units, ie the display, would need to be sent away for the code to be retrieved.
    For complete reading and reprogramming of a new code, both items will need to be sent off.
    The service will involve you sending the headunit only to the Czech Republic and will take approximately 3 weeks (2 of which will be travel time). No external wiring is provided and so you will need to add this yourself afterwards. Payment should be by Wire Transfer, Paypal, or the comparatively new Transferwise Service. If paying via Paypal the cost will be 4% higher due to the Paypal Fee.
    I can however personally recommend the Transferwise Service offered here -
    https://transferwise.com/?utm_source...fhixoCwQPw_wcB
    This will allow you to pay online in Euros with a Visa or Mastercard Bank Debit Card with a fee which is a small fraction of the charge typically levied by banks in the UK.
    PLEASE NOTE - THIS PRODUCT RANGE IS NOT SUITABLE FOR THE INSIGNIA
    I will be pleased to answer any questions you may have either by PM, or you can email me at - woodpeck54@gmail.com
  2. Thanks Das thanked for this post
    Likes Das, Syko, michale_kid liked this post
  3. #2
    May 2012
    211 Post(s)
    Mileage : 131,000
    So what if I have an Aftermarket Non OEM Headunit ?
    If you have changed headunits, all is not lost
    The Comfort Unit can also be easily controlled using your Left Steering Wheel controls and the menus and options are displayed and selectable exactly the same as if you still had your original GM Headunit.
    The same goes for the Video Modules (VCU-01 & VCU-02) and so all of these items can be fitted to vehicles with either the Factory Headunit, or an Aftermarket Model as long as your GID / CID is compatable with the models shown in the PDF's and that you have the "scroller" type of steering wheel controls found on facelift cars.
    PM or Email me with any Sales Enquiries or other questions on installation.
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
  4. Thanks Das thanked for this post
    Likes Das liked this post
  5. #3
    May 2012
    211 Post(s)
    Mileage : 131,000
    Retrofitting Aux In to a CD70 / DVD90 for pre 2007 models
    To have Aux In retrofitted will involve updating the firmware in the headunit using a 2007 Update Disk which costs under £10 from the Vx Main dealer.
    Apart from that however, the internal circuitry of the headunit will need some new components added. The component are mainly Resistors and Capacitors although there is also a special Integrated Circuit (IC) chip which will need soldering.
    Beware though, even if you do manage to source the components, the soldering of these SMD (Micro Components) will be beyond the ability of many would be DIY'ers due to the size. If your soldering abilities with this type of component fall below that of a "specialist" then my advice would be to pay someone who has the knowledge and skills to do this for you.
    Such an individual will already have the update disk in their posession and so your purchase of a disk, if you bought one, will be wasted money and so you might want to consider whether you even need to purchase the disc yourself.
    To give you an example of how the CD70 or DVD90 will work once the firmware has been updated, I am posting the following links from the www.PepaS.cz website. The youtube examples will show you how the headunit will perform as far as sound output is concerned when only the firmware has been updated, and then secondly, when both the firmware update has been completed AND the additional components installed/fitted.
    Please turn up your volume and "listen" to the difference between the 2 examples to see what I mean
    CD70/DVD90 with Firmware Update Only (Non Functional Aux In)
    CD70/DVD90 with Firmware Update AND New Internal Components Fitted (Fully Functional Aux In)
    For anyone interested in doing the modification themselves, here is a link to the PDF for the Aux In Retrofit carried out by Pepas.
    http://www.pepas.cz/wp-content/uploa...UX-IN_v1.0.pdf
    When comparing the components used, you will see that although the list bears some similarities to the modification published by YYSNET, it is actually different, with several items using a different value.
    I am advised that the effect of using these components & values is better from the audio quality point of view (higher bandwidth, greater sensitivity).
    Last edited by Woody; 10th August 2015 at 15:12. Reason: Added PDF Download Link for the retrofit instructions
  6. Thanks Das thanked for this post
  7. #4
    May 2012
    211 Post(s)
    Mileage : 131,000
    Default Add Video Aux In and TV / Media with a CID - Add TV to your CD70 setup
    Now you can watch TV on your CD70 with CID and Aux In.
    Add a VCU-01 and a Raspberry Pi to your CD70 with Aux In, and you too can be playing your media files or watching live and catchup TV with a Raspberry Pi Connected and running KODI (formerly known as XBMC).
    I am now connecting my Raspberry Pi2 to my phone (using my phone as a "Hot Spot") and can now watch live or catchup TV using BBC iPlayer, ITV Hub, Youtube and other online TV / Movie / Media Internet "apps" as well as my stored media (movies/music videos/mp3's etc).
    This little cigarette pack sized media PC is SUPERB.
    As a result, I have added the photos of the new case into the main sales thread in post 1.
    Another option for video / audio connections is a mirror device, this will allow you to see on your CID and listen to on your car headunit (using Aux In), whatever media your phone is playing.
    Obviously, none of this activity involving video media should be selected or viewed whilst your car is being driven. Due to the obvious safety issues, the penalties for viewing media whilst driving are understandably SEVERE.
    As always, feel free to PM me with any questions.
    Cheers
    Woody
  8. Thanks Das thanked for this post
    Likes TheEpicSponge, Das, michale_kid liked this post
  9. #5
    May 2012
    211 Post(s)
    Mileage : 131,000
    Default Comfort Unit / Reversing Camera / DPF & Turbo Monitor, Parking Sensor Display & Much More
    Thought about adding a whole host of new features to your car ? Think about a Comfort Unit & Also possibly adding Video & Reversing Camera and Even the KODI / XBMC Media Player to your CID for media playback of movies, music videos, mp3's and even live and catchup TV
    For New Members, and also for those who have not yet managed to find their way to the "Vectra-C.com Trader Section" , I am offering the following enhancements ....
    Comfort Unit is designed to add lots of new features to facelift Vectra-C and Signums. Also to Astra H and Zafira B models with compatable headunits & screens. Even more features are offered to drivers of VXR / OPC Engines.
    Video Module VCU-01 (or simply just a VCU-02 with No need for a Comfort Unit), and you can then consider adding a reversing camera andts multimedia player options to cars with a CID Colour Screen.
    Your CD70 hasn't got Aux In ? ... No problem, this can be retrofitted to factory spec.
    Just "Click" on the following link to "read all about it"
    Upgrading your CID to the latest 3 line Animated Display is also offered.
    It is all covered in this link
    https://www.vectra-c.com/forum/showt...m-www-PepaS-cz
    Please PM me with any questions
    Cheers guys
    Woody
  10. Thanks Das thanked for this post
  11. #6
    May 2012
    211 Post(s)
    Mileage : 131,000
    Talking Add a Turbo Boost Readout, a DPF Regen Indicator, and so much more
    How would you like to add such features as -
    Turbo Boost Readout.
    EGR Regen State.
    VXR Dial Sweep and Dash Lights Illumination (just like a Vxr).
    Digital Speedo
    Digital Temperature Gauge
    Battery Voltage and Charging State
    Park Pilot Parking Sensor Display (on screen) of Sensor Positions
    Aircon System Pressure (ECC Units Only)
    Overspeed Warning Beep (set by user)
    Coming Home / Welcome Home Lights
    Massive Volume Speed Increase / Decrease via steering wheel scroller controls on headunit.
    And more ?
    And with a Vxr Engine MUCH MUCH More
    A Comfort Unit is also a potential starting point to adding menu controlled multimedia input to suitable headunits and simply just plugs into your OBD Diagnostics Port under the ashtray.
    If you have a facelifted full canbus Vectra-C / Signum these can be menu driven additions (just as if they were factory fitted by Vauxhall Opel) with suitable headunits and displays.
    If you haven't already "found" this information, then you can click here - https://www.vectra-c.com/forum/showt...m-www-PepaS-cz
    Or the link in my signature file, and if all else fails, just send me a PM
    An "ideal" New Year "Gift" for your Vectra / Signum and will give you new "menu driven" options and yet save you significantly on the cost of other instrumentation which won't provide any "near" equivalent to this kit
    Very Best Wishes for a Happy and Healthy New Year ahead in 2017 to to all my friends, and fellow members, and of course my existing Customers
    Woody
  12. Likes Teapot, pattz123 liked this post
  13. #7
    May 2012
    211 Post(s)
    Mileage : 131,000
    Wink Driving Abroad in 2017 ? Fancy a Digital Speedo showing KM/h ?
    Driving Abroad in 2017 ? Fancy a Digital Speedo showing KM/h ? Or, are you in the UK driving a European Vectra-C / Signum and would like a Digital Speedo showing Miles Per Hour rather than trying to cope with a KM/h standard speedo ?
    Well you can this Digital Alternative Speedo option with a Comfort Unit installed in a compatible vehicle.
    After an existing UK member / user asked whether he could display the digital speedo option showing his vehicle speed in KM/h instead of in Miles/h for when driving in France, I checked out the "options"
    Yes, your Comfort Unit will display a digital speedo readout showing kilometres per hour rather than in miles per hour (or MPH rather than your standard European Speedo readout) if the settings for the main display itself are changed.
    This could prove to be an extremely useful feature for drivers travelling abroad in UK vehicles, or when in the UK with European LHD vehicles, especially when used with the overspeed warning settings.
    For the benefit of existing customers, just follow the settings changes below -
    The digital speedometer "units" can be selected in the Standard Display
    Settings Menu
    -Settings / Units / Europe-SI (km/h) or Great Britain
    (Imperial units - mph).
    Due to my car being off the road right now, I have been unable to verify this information, however, I have no reason to doubt its authenticity as it came straight from PepaS
    But if anyone would care to check, I would much appreciate it - possibly @RichM or @HarrysDad ?
    Last edited by Woody; 31st December 2016 at 21:22. Reason: Post tidy to reflect Euro Vehicles used in the UK
  14. #8
    May 2012
    211 Post(s)
    Mileage : 131,000
    Default Promotion - Free 3 Line CID Display Upgrades for Existing (and New) Customers
    PROMOTION - Free 3 Line CID Display Upgrades with NEW Animated Startup Screen.
    Yes, FREE, if you are an existing or new customer of a PepaS product from me - you just pay the cost of the carriage.
    Estimated turnaround time, from you despatching the display, to receiving it back, around 3 weeks.
    Get things organised so you are ready for this years shows.
    The 3 line display upgrade to a Colour Information Display (CID) will offer a revised choice of animated graphic screens on startup. However, the existing animations are indeed very limited.
    So, this offers you 2 additional alternative ROM Updates with some unique animated screens for VXR / OPC options.
    I am now offering the three line update, with either the original GM screens, Or one of the 2 new screens shown below, free of charge (you just pay the postage).
    This special offer is open to existing and new, customers of mine with PepaS products.
    Please PM me for the exact cost details for carriage etc, BUT effectively, for the cost of post only, you can take advantage of this deal shown below, if you are an existing, or new PepaS/Woody Customer.
    If you would like the standard Vx 3 line display conversion on a CID display, then this is also available for this promotion for the same price.
    So, you have already purchased a Comfort Unit, or a VCU-02 ? Yes you are elligible , If not, just get yourself a Comfort Unit, or a VCU-02 ordered, so as to qualify for this bargain offer.
    Here is a breakdown of the savings for someone having an Aux In Retrofit and a CID Display upgrade -
    1 - Not an existing Comfort Unit customer
    CD70Navi AUX Input retrofit.......................... 50 EUR
    CID FW Update (3-lines BC and VXR startup screen).... 40 EUR
    Return Postage (by UPS Standard)..................... 23 EUR
    Total............................................. .. 113 EUR
    2 - An existing customer
    CID FW Update (3-lines BC and VXR startup screen).... 0 EUR
    Total............................................. ... 73 EUR (approx £61.59 at 20/2/2017)
    Think of this as a potential Comfort Unit Cost Saving of €40
    Of Course, you do not need to purchase an "aux in retrofit" to "qualify" for this. If you wish to have a 3 line firmware upgrade, with a special startup / shutdown screen then you can simply choose this
    3 - Not an existing Comfort Unit customer
    Total............................................. .. 63 EUR
    4 - An existing customer
    Total............................................. ... 23 EUR (approx £19.00 at 20/2/2017)
    Just PM me for more details as needed
    The "Start Up" and "Shutdown" screens are here -
    Standard 3 line display firmware options
    Startup Logo – OPEL Animated
    Startup / Shutdown Logo - HOLDEN
    Startup / Shutdown Logo - CHEVROLET
    Startup / Shutdown Logo - VAUXHALL
    Startup / Shutdown Logo - OPEL OPC / VAUXHALL VXR
    The "PepaS Alternative" 3 line display firmware alternative options for OPC
    OPC - Animated OPC Startup with Still Opel Shutdown
    The "PepaS Alternative" 3 line display firmware alternative options for VXR
    VXR - Animated VXR Startup with Still Vauxhall Shutdown
    Youtube Demonstration Videos of the PepaS Alternative OPC and VXR startup/shutdown screens in and working
    OPC CID - New Startup Animated OPC Logo with Static Opel Shutdown Logo
    VXR CID - New Startup Animated VXR Logo with Static Vauxhall Shutdown Logo
    PS - For viewers watching the youtube VXR video, please note that unfortunately the video capture "started" with the headunit shutting down - To visualise the finished product, you should start to "take note" around 8 seconds into the video to get the "complete picture"
  15. Likes michale_kid liked this post
  16. #9
    May 2012
    211 Post(s)
    Mileage : 131,000
    Wink DPF Regen with a Comfort Unit fitted
    DPF Regen with a Comfort Unit fitted. Applies to full canbus Vectra-C / Signum / Astra-H / Zafira-B models with DPF.
    Thanks to @Matty2Fatty for a video he took whilst on a road trip recently
  17. #10
    May 2012
    211 Post(s)
    Mileage : 131,000
    Default Comfort Unit - Latest Features & Firmware version 4.3de
    Comfort Unit - New Features.
    After some questions from an Astra-H Vxr driver recently, I realise that Vx drivers may not appreciate the availability of several new features offered by the latest 4.3de version of the Comfort Unit Firmware
    Z28NEH Z28NEL Z28NET Engines (including the Vxr)
    Z20LEH Z20LEL Z20LER Engines
    If you have a Vectra-C / Signum / Astra-H / Zafira-B with one of the above engines, a full range of live engine data can now be monitored full time on a suitable Vx display. This can be selected from either the headunit buttons, or the steering wheel controls, or, where the original Vx headunit has been replaced with an aftermarket unit, via the steering wheel controls if you can still access the Vx screen from the steering wheel.
    Here is a link to download a supplemental PDF file to explain the newer features. A youtube video link to show the ECM in action is viewable in post #1 on this thread.
    http://www.pepas.cz/wp-content/uploa...on_ParList.pdf
    For all suitable vehicles, in addition to the above, the latest firmware offers a light dependant coming home lighting for those cars equipped with autolights and when the daylight (night time) condition is such that headlamps were active just prior to switching off the ignition.
    Another new feature is the option to select the front foglights for use as DRL's when the main/sidelights are switched off.
    A "free" firmware upgrade is available to ALL customers who have purchased their units through me. All you are required to pay is the cost of the return carriage. "Second Hand" units can be updated for a small charge.
    All new CU's are being shipped with the latest 4.3de version of the firmware.
    For FULL details on the amazing features offered by adding this superb little module to your car, see post #1 in this thread.
    Any questions ? Well you know how to get hold of me
    Woody
  1. comfort unit, what do i need?
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2014, 23:04
  2. What does the comfort unit do?
    By rob1981 in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2014, 16:23
  3. Hello from the home of Opel
    By TTC in forum Introduce yourself.
    Last Post: 7th December 2007, 12:22
  4. Home made Opel mods
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2006, 22:13
vectra c comfort unit
comfort unit
pepas.cz comfort unit
vectra c comfort module
https:www.vectra-c.comforumshowthread.php213425-Woody-s-Vx-Opel-ICE-Home-of-the-Comfort-Unit-and-Accessories-from-www-PepaS-cz
Adding Video Aux Input to your Vauxhall Opel Colour Screen
opel aux usb sdcardopel vectra komfort modulCID firmware display 3 lineastra h aux girişivauxhall cid 3 lineopel logoprogram needle sweep vectra cmodule cid video opel vectrapepas comfort unit signumastra cid displaycomfort unit vectra cconfort closure boz location vectra copel vectra c komfort modulopel comfort unitcd70 navi usbpepas cz vectra c Pepas Comfort Unitcomfort unit opelvectra c komfort modul
