Ah, I see. Thank you!
Have you done it ?
if you don't manage to get it out that way try pulling one of the knobs on the left/right, this helps unclip the panel on one of the edges. but my esteemed northern colleague has reccomended the best method. good luck!
Well I managed room get the unit out by wiggling it out. The lower parts was completely stuck.
I have tested the button and it seems the it is working better when put my finger on the backside of it when pushing the button.
My equipment is very old and way to big for those small parts, so I've managed to find a technician in the house who is in to RC flying and drones... He has a small soldering tool and I'll get it tomorrow... Do I just "add" to the existing pins or do I take it out and solder it back on/on.
Best regards,
Kristian
Have you disconnected the 2 large connectors on the rear ?
I do not advise doing any soldering to the unit while it is still connected.
I understand that the "fix" is simply to re-solder the existing connections and NOT to remove switch
HTH
Surely I will disconnect
So now it is soldered and I think I can feel some improvement... I still have to push quite hard and it doesn't work every time.
I'm going to try it out and otherwise maybe I'll need to get a new one.
Kristian
Nice one, let's hope you have fixed the problem
