Hi, quick update. Remap done, thanks to Paul (Littleteapot). Managed to do it remotely with Paul's help, which in the end, went quite smoothly.
Next step is to run it for a while to see if any further tweaks are required. Main aim was to eek out some more MPG from the car (Vectra C CDTI, 1.9DT 120). On a long run normally used to get
approx 51mpg, (brimming the tank) so will be monitoring this over the next few long trips. Car in general feels better all round, hopefully with Paul's help I can get some more MPG out of the car.
Thanks to Paul for his help to-date, easy recommendation to anyone looking to have a remap done...
Further update. Paul (Littleteapot) has been doing some further tweaking to the mapping. After many long runs and alternate maps we are currently getting approx 54mpg (previously 51mpg) when doing 60-70mph full runs.(brim to brim...) There may or may not be more tweaking to be done, Paul still mulling the subject at present. Power wise is similar to before, a lot smoother throughout the range. Aim was not power, but, mpg improvement. Temp gauge is bouncing around, but think the thermostat is on the way out, expect that to be sorted in the next couple weeks of weeks.
Once I get some more updates will post accordingly......
Well, at the end of the re-map tweaks. Topping out at approx 54.5mpg (brim to brim) and thanks to @littleteapot for all his work.
Aye Paul's helped me out too so defo one to use if wanting a remap or whatever .
Yes, not many areas he has not been involved in. Whole process was done remotely with no issues which was good.
