Results 1 to 9 of 9
Thread: HID FAQ: Facts about HID Lights
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Question HID FAQ: Facts about HID Lights
    WHAT DOES "HID" STAND FOR?
    HID stands for High Intensity Discharge.
    WHY SHOULD I UPGRADE TO HID XENON LIGHTS?
    Safer night driving
    Xenon lights are 3x brighter than halogens. At night this is very crucial because the lack of visibility is the biggest cause of automobile accidents during night time driving.
    Larger viewing radius
    Xenon light bulbs will have 70% wider road coverage due to the fact they are brighter.
    Clearer visibility
    The whiter xenon light penetrates darkness better than the yellow halogen light and as a result you are able to see better in tougher weather conditions like rain, snow, and fog.
    Longer bulb life span
    Xenon bulbs last 3x longer than halogen bulbs, and withstand a greater amount of vibration and shock from the road. The average life of a Xenon bulb is about 2,500 hrs.
    Lower energy consumption
    Xenon lights consume 25% less power than halogen headlights.
    HOW LONG DO HID BULBS LAST?
    HID bulbs last approximately 2500-3000hrs. Under normal use you should get about 4 years of service from an HID bulb.
    WHAT IS INCLUDED IN AN HID 35W CONVERSION KIT?
    HID Conversion Kits include:
    2x Slim 35W AC Ballasts or 2 Canbus 35W Ballasts
    2x Xenon HID Bulbs
    2x HID Plug'n'Play Wires
    Screws & mounting brackets
    Installation Instruction
    WHAT IS CANBUS BALLAST?
    CanBus Ballast eliminates flickering issues or "headlamp out" error light issue. Can be used on all make and models but are recommended for all BMW, Audi, VW, and Dodge conversion kit installations.
    WHAT IS THE DIFFERENCE BETWEEN AC & DC BALLASTS?
    AC ballasts have a longer bulb and ballast life, are brighter and more expensive.
    DC ballasts have a shorter bulb and ballast life, and are inexpensive. DC HID conversion kits may cost as little as £25.
    WHAT IS THE DIFFERENCE IN BRIGHTNESS BETWEEN 35W, 55W and 75W HID KITS?
    35W - 3x brighter than halogen bulbs
    55W - real live testing shows about 10% increase in brightness over 35W systems
    75W - 2x brighter than 35W HIDs. Bulbs have a shorter life span because they run hotter.
    CAN 35W BULBS BE USED WITH 55W BALLASTS?
    The answer is YES. When a 35W bulb is used with a 55W ballast the light will be brighter but at a lower temperature (colour). For example, a 35W 6000K bulb when used with a 55W ballast will have 5500K colour. The life span of the bulb will not be affected.
    WHAT IS THE DIFFERENCE BETWEEN CREE AND EPISTAR LED?
    CREE LED's are made in USA.
    Cree Inc. is a multinational manufacturer of semiconductor light-emitting diode (LED) materials and devices, headquartered in Durham, North Carolina, USA
    EPISTAR LED's are made in Taiwan.
    Epistar Corp. is the largest manufacturer of light-emitting diodes (LEDs) in Taiwan.
    MY LIGHTS KEEP FLICKERING AFTER INSTALL. WHAT DO I DO?
    If your lights keep flickering after install then the ballasts are not getting full voltage required to ignite the bulbs. To solve the problem, install a relay
    wiring harness. The harness connects directly to the battery, and the low voltage is capable of switching the relay, which then draws full 12-14V from the battery, and your HID bulbs will ignite. This setup is normally required for high beams which operate DRL's.
    Installers Note: If you installed a relay harness and your lights still keep on flickering, then (a) you may need to install resistors (b) your battery may be old (6+ years).
    I WANT TO INSTALL HID'S IN MY HIGH BEAMS. IS IT POSSIBLE?
    Yes, it is possible, but keep these points in mind:
    1. If vehicle's high beams are also the vehicle's DRL's then you will need a relay harness. DRL's will run full-on HID's, even in daytime.
    2. HIDs take time to warm up (10-15 seconds) to full brightness, so if you use your high beams only for short times, then HID's may not be of great benefit to you.
    WHAT DO I NEED TO INSTALL HIDS ON A VEHICLE WITH DAYTIME RUNNING LIGHTS?
    HID INSTALLATIONS ARE TRICKY BUT NOT IMPOSSIBLE.
    HERE IS WHAT YOU NEED TO KNOW:
    1. Install CANBUS PRO ballasts with your HID bulbs
    2. If HIDs flicker with CANBUS PRO ballasts then you need a
    RELAY
    3. If HIDs flicker even after installing a RELAY you will need RESISTORS
    4. If you get a "Lamp Out" warning, you will need to install a
    Warning Canceller.
    WILL I HAVE PROBLEM WITH POLICE IF I INSTALL HID LIGHTS IN MY CAR?
    There is no simple answer for this and it will largely depend on the police officer and the reason why you got pulled over. Logical assumption would be that trucks with 3 sets of HID lights turned on during the day speeding down a school zone are more likely to get pulled over than someone with a set of HID lights turned on at night time driving the speed limit.
    The colour of HID lights has a lot to do with it as well as the type of headlight in which they are used. HIDs come in different colours with 4300K being OEM HID colour, 6000K white, 8000K bluer, 10000K blue, 12000K purple-blue, etc. Basically if you use any colour lower than or equal to 6000K you should be fine.
    Headlight type - headlights with diffusers built into the lens (lines in the lens itself) scatter the HID light all over and are the least desirable for upgrading to HID bulbs. Clear headlights with diffusers built in and projector style headlights are probably the best suited for upgrades to HID because they diffuse the light before it hits the road, and lower the chance of blinding oncoming traffic. So, be sensible about how you use your HIDs. If everyone is flashing you then you should lower your lights. Be considerate. You will still be able to see without being "annoying" to other drivers. In summary, upgrading to aftermarket HID lights in your vehicle (one that did not come with HID lights) is entirely your decision. Aftermarket HIDs are not always E marked, and are intended for "off-road" use only, so there is a chance you could be asked to remove them. That said, many people upgrade their car lights to HIDs for safety and better night visibility.
    Jan 2017
    West Yorks
    Vehicle : Vectra C
    Trim : Design
    Engine : 1.8
    "Aftermarket HIDs are not always E marked, and are intended for "off-road" use only, so there is a chance you could be asked to remove them"
    Could this cause problems at MOT time?
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    Quote Originally Posted by Odd Job View Post
    Mine went through 4 or 5 MOTs without comment.
    Generally aftermarket HIDs will only cause you a fail if they're too blue, out of alignment, or causing too much beam scatter.
    Regular Member scutt_123's Avatar
    Jan 2017
    West Sussex
    Vehicle : Signum 2.2
    Trim : Design
    Engine : 2.2
    I just brought a HID kit for my 2004 signum, un packed everything, pulled the main beam headlight out ready to connect the exciting harness to the ballest and they are both completely different plugs. I can't seem to locate the correct kit. Is there an adapter? And has anyone else have the same problem.
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by scutt_123 View Post
    What are completely different plugs?
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Jan 2017
    West Sussex
    Trim : Design
    Engine : 2.2
    The plug that's on the ballest that plugs into the plug for the headlights are different
    Oxfordshire
    13 Post(s)
    Engine : 2.0 CDTi
    Year : 2013
    Are they spade connectors on the ballast leads - they usually are.
    If so, all you need do is identify which is the +ve and -ve on the car's headlight plug and push in the spade connectors into the headlight plug, then for good measure wrap tape around to keep any moisture out.
    Mar 2010
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I probably would have gotten around to fitting HiD, but after doing the "fix" on the dip beam height, and fitting 90%+ bulbs I was happy enough that I could drive safely.
    I'dve likely gone for 4300k 55w. Oddly, Cree supplies the diodes etc for my torch, a Lenser, puts out a hell of a lot of light off 4 AAA batteries that last for months.
    Mar 2009
    Lisbon
    Hid
    Enviado do meu Vodafone Smart ultra 6 através de Tapatalk
  1. A few facts
    By BlueRob in forum Comedy & Humour
    Last Post: 27th October 2008, 21:32
  2. the facts with the new map
    By chrisgettings in forum Diesel Engine related
    Last Post: 29th April 2008, 19:59
  3. funny facts
    By ditchp in forum Comedy & Humour
    Last Post: 17th November 2007, 23:35
  4. VXR Mileage Facts ....
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2007, 21:48
  5. Mrs D's pointless facts.............
    By Mrs D in forum Comedy & Humour
    Last Post: 13th October 2005, 00:19
Will a 55w hid kit damage my Vauxhall insignias wiring
i fit drls to my vectra why do they keep flashing after i switch car off
vectra c hid
vectra c hid headlights
hid 6000k or 8000k vauxhall vectra
brightest xenons vec c
insignia hid kit
vectra c led headlights 55w
Installing hid vectra c plug and play no drilling
vectra c xenon type bulb
hi beam hid bulbs flickering vectra 2008
hid anti flicker capacitors installation vectra c hi beam
Vectra c xenon adapter
hid vectra c
important facts about HID
vectra c hid fog flicker
canbus hid vectra c indicators on
hid kit wiring vectra c
vectra c bulbs 55w or 35w
can you use a 35w hid bulb in a 55w ballast
vectra c hid to halogen wiring kit
vectra c high beam hids
35w vs 55w hid insignia
vectra c hid bulbs
vectra c hid kit 4300 55w canbus
