I see the video now. What I'm not sure of is whether you have also updated the display to a 3 line display ?
I am lead to believe that the fuel warning feature is removed when you "update" the CID to show a 3 line display.
Yes it is a 3 line display, do not remember if it was a part of the uppgrade 3,5 years a go.
Kristian
68 Diplomat-A 46S
95 Vectra-A C20NE
07 Vectra-C Z19DTH
So, I guess we need to know more about what you have done then
If you had the 3 line flash some years ago and have only just adjusted the opening screen, maybe there is some hope for others like me who had both done at the same time and lost the "range warning message" in the process
the one reason I have not had mine upgraded to 3 line is the loss of low fuel warning, so interested to know how you solved this
The solution was actually quite simple. Reset CID to delivery mode and program again.
Kristian
68 Diplomat-A 46S
95 Vectra-A C20NE
07 Vectra-C Z19DTH
I'll try, but I'm pretty sure I already did that at one point. Tech2 or opcom?
The easy way to tell if it's an upgrade or a legit 3-line CID is to show the back of it.
Most 2 line CIDs will run ident DB / part number 24461297, if a DB CID is running 3 line firmware, it's an upgrade.
From hazy memory and a brief prod on EPC, I think the legitimate 3 line CID has ident BH / part number 13275009
I useTech2 and my display have ident db.
Kristian
68 Diplomat-A 46S
95 Vectra-A C20NE
07 Vectra-C Z19DTH
Nice one
Mine is ident DB (now with 3 lines and Vxr opening screen)
Source Address: DIS
Identifier: 0x1302
VIN: W0L***********
System name: CID/GID Epsilon
Hardware number:13128263
Part Number:24461297
Software version number: CE83-/00050
System description: SIEM 0400
Alpha code: DB
Code Index and version: 011 00
Looks like a "test" for @plasma next time I can get him somewhere near my diagnostic port
Nice one @sulten
