Thread: Water leaks in boot?
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Default Water leaks in boot?
    Hi Guys,
    Im planning on trying to tackle/locate/diagnose a water leak into my Dad's boot.
    He has an 02 Elite 4dr and we noticed water at the back Right corner inside the boot...he says it drips in when its raining and he has the boot open...hmm...
    I sort of went along with that until i was doing a full valet on it and stipped the boot out...and found about 3inch of water in the spare wheel well...not good i thought, obvious water leak.
    Im initially thinking the obvious in the rear light seal, but just wondered if anyone else has had similar leaks and they were from another area?...i really cant see it coming from anywhere else really, and it cant be sunroof drain pipes, as it has no sunroof lol
    Any advice greatly appreciated
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    my silver vec started doing this and it turned out to be the seal on the airel leaking and was running down inside he bodywork and filling the spare wheel well
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Could also be the rear quarter glass.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by Beavis View Post
    Ta...aye i saw the other thread on the ariel base just after i posted this, but that seemed to leak in down the left hand side...although i suppose water goes where it wants lol
    Couldn't...its a 4dr as i mentioned...so no quarter glass
    Feb 2007
    North west
    i cant remember what car it was on but ive seen a leak like this from a missing rear light seal (one side had no gasket ??) and also from a missing drain plug, the matting acting as a wick when driving on wet roads and drawing water into the boot. Obviously cant be the drain plug if there is a pool of water - unless theres a hole somewhere not at the lowest point with carpet covering it ?
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by rob 2.2dti View Post
    Cheers Rob...
    Rear light will be my first point of focus (oh god, i mentioned a F**D! ), then i think the ariel seal...ive got a tube of silicone so should be OK with those.
    No sign of any holes anywhere for ingress...only other sort of area i considered was the fuel filler, but that seems well sealed...i just remember Carltons pouring in through the locking 'bolt' lol
    Regular Member vectravirg's Avatar
    Bolton
    Found exactly the same on mine about 2 inches of water in the sapre wheel well, further investigation looked like it was coming from near the drivers side rear light.
    It was getting dark last night when I discovered it, will have another go nexrt time when it's light.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    I sorted this now i hope, see my other thread here:
    http://www.vectra-c.com/forum/showthread.php?t=64807
    (Sorry too as i didnt realise i had two threads)
  1. still water in boot
    By cutchy in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2012, 20:56
  2. water in boot
    By keggy77 in forum Bodywork & Interior
    Last Post: 15th May 2012, 13:03
  3. Water in Boot
    By bigmac in forum Bodywork & Interior
    Last Post: 9th April 2009, 20:12
  4. water in the boot
    By billyyoung in forum Bodywork & Interior
    Last Post: 9th January 2008, 18:58
  5. Water in the BOOT!!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2007, 09:06
vectra water in boot
vectra c water leak in boot
vectra c water in boot
vauxhall insgnia boot water leak left side
insignia water in boot
vectra c boot water leak
vectra c boot leak
water in boot of 2008 vauxhall vectra
leak in boot vaukhall vectra c
vectra c water in boot side com
vectra c leaking both sides at back
water leaks in vectra c boot area
2005 vauxhall vectra boot leaking
vectra c water in the boot
insignia water leak
water in boot vectra c
vauxhall signum boot keeps getting water in
vauxhall vectra rear light seal
water leak in boot vauxhall vectra
vauxhall vectra water in boot
https:www.vectra-c.comforumshowthread.php21254-Water-leaks-in-boot
Vauxhall Vectra 07 leak in drivers side rear quarter
water getting into vauxhall vectra c
insignia boot leak
vectra boot leak
