Thread: Metal Fabricators
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default Metal Fabricators
    I'm after place that will fabricate a set of spigot rings. (just abit of tubing)
    the basic dimensions are:
    65.1mm inner diameter
    66.6mm outer diameter
    (wall thickness 0.75mm)
    20mm section length
    anyone know of a place?
    Carl
    Mileage : 000
    How many is a set.?
    sorry, a set is 4
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    To be fair, I would have thought that the best way to do this would be to roll some 0.75mm thick stainless strip 20 mm wide and then weld and finish off the weld area.
    You're not really going to get this turned easily, or cheaply for that diameter.
    Is it for your wheel / hub centre diameter? If so, I think this would be the best course of action, and wouldn't be too hard to do.
    You may even get away with not welding it at all, it wouldn't do much anyway (if it's for your wheel hub centres)
    yeah it is for the wheel hub centres.
    i was thinkin about doin that way.
    just thought i would ask around and see how much it would cost to get some made, ive got no idea about prices for this sort of work.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    In that case just work out the length you need (206.5mm), cut the pattern, roll and place around the centre hub and attach the wheel.
    Could do it very quickly, if you got the right material.
    I'll have a look at work and get some guillotined, not sure about the rolling of such a small diameter, but i'll check.
    If I can get some done I'll send you a PM for your address and post them.
    Can't promise anything, and it would be tomorrow now anyway as our prototype folks will have left already. All depends on if we have some material.
    Mileage : 000
    I will be able to turn some for you either out of aluminium[if we have got any] or ordinary mild steel,[ might rust though].
    Quote Originally Posted by Ste View Post
    nice one mate, that would be great, cheers.
    what sort of price woul di be lookin at for aluminium ones mate?
  1. Sounds like metal-to-metal from the rear.
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2014, 12:01
  2. Vectra-B brakes sound like metal to metal
    Last Post: 4th December 2011, 14:42
  3. metal on metal noise
    By neill in forum Engine & Drivetrain
    Last Post: 1st February 2011, 18:33
  4. metal on metal maybe?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2010, 17:57
  5. Any metal fabricators on the forums?
    By Ian-Highlander in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2010, 10:16
