Results 1 to 2 of 2
Thread: Engine cuts out (1.9cdti150)
    Mar 2007
    Stourbridge
    Question Engine cuts out (1.9cdti150)
    I have had several instances of the engine suddenly cutting out, scarey when on a dual carriaway or motorway. Today it happened just as I was going round an island. Engine restarted ok but power steering did not work. had to pull off and stop and restart all ok. When this happened previously took it to dealer - no faults in in EM log & was charged £60 for EMS reload. Strange thing- over the weekend the radio turned itself on twice during a journey after what sounded like a cough throught the speakers. The cutting out is starting to scare me as I spend 90% of my time on motor ways. Anybody got any similar problem or solution. Thanks
    Regular Member OilBurner's Avatar
    Feb 2006
    Bromsgrove
    Could it be the old wiring harness problem?
    The early versions of the 1.9 CDTI sometimes rubbed the engine bay against the transmission tunnel wiring harness through to the wires, causing random short circuits etc.
    That seems quite likely given your symptoms. I would hope the dealer has checked for that problem, it's mentioned on the Honest John website, so must be quite common.
    The solution was a new re-routed wiring harness.
  1. 2.0 Dti engine cuts out Signum
    By martutd in forum Engine & Drivetrain
    Last Post: 19th March 2012, 08:35
  2. Engine Cuts Out
    By bulletproofpanda in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  3. Engine cuts out
    By Lloydy in forum Engine & Drivetrain
    Last Post: 26th May 2010, 12:52
  4. engine cuts out
    By thedhj in forum Engine & Drivetrain
    Last Post: 7th February 2010, 14:07
  5. Engine cuts out
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 09:22
