Results 1 to 10 of 19
Thread: Tyre widths
    Regular Member NAYLAD's Avatar
    Mar 2007
    WESTERN ISLES
    Default Tyre widths
    Hope I havent missed this in earlier posts.
    Seems logical that wider tyres would help roadholding.
    I have standard 17" wheels, whats max width possible, or would I have to change wheels to gain width?
    you could stretch it to 235's.. but no wider on standard 17's...
    we run 225's on the vec and siggy..
    Ironically, wider tyres don't always lead to better roadholding
    Compare :
    205/55R17
    215/50R17
    225/45R17
    All three should fit the standard VX alloy wheels, and they all pretty much have the same surface area on the road
    The 55 aspect tyre will have a more relaxed feel on general driving
    The 45 aspect tyre will have a more firmer feel on general driving
    As the aspect decreases the ride quality deteriorates, as does the risk of kerb and road surface damage
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Depends on the width, most Vx 17" wheels are 7" width. The 235/45 R17 are not recomended but will fit fine and I've run that size in three different tyres with no fitment problems. The 235/50 R17 is recomended down to 6" width so you could go for them but they are larger and so would put your speedo out slightly (no more than 2&#37.
    The wide the tyre, the more grip you will get but the more feed back you will get from the road. You will probably find torque steer increases, if you have some now. Also, if you go into the slow lane on the Motorway, the big ruts left by HGVs will make the car pull all over the place.
    Another thing to think about is tyre pressure, you may have to increase the pressure slightly as you increase width to achive uniform wear (more rubber = more flex obviously).
    And if you don't have mud flaps, expect stone chips on the side of the car.
    Compare :
    205/55R17
    215/50R17
    225/45R17
    How do you work that one out? The 225 width tyre will have more surface area (10% more) on the road than the 205 width tyre as it's a wider tyre by 20mm.
    That's just the way it is
    With the 205/55R17 tyre the tread has greater flex
    With the 225/45R17 tyre the tread has less flex
    As a result they both have the same % ratio of road surface area, and as a result do not affect the speedo reading
    If they did have then the speedo reading would also be affected
    The air volume in the tyre would also be different and not only would you need to work out the ratio of tyre you needed but also the comparative speed rating, but as it is you don't
    Take actual measurements of the surface area for all three tyres and compare
    Regular Member Faz's Avatar
    Feb 2007
    Birmingham, West Mids
    eg 225/45/17
    The tyre width i.e. 225 refers to the width in mm. Therefore 20.5cm
    The tyre height i.e. 45 refers to the height as an aspect ratio of the width. i.e. 45% of 225 = 101.25cm
    This is why not all '45' height tyres are the same height, as it depends on the width.
    I think you're getting mixed up here? The overall diameter and circumference of different width/profile combinations can indeed remain the same and not affect the speedo - but that's not what I was saying.
    I was referring to the amount of surface area of rubber that met the road - that's what determines grip - and with a wider tyre it's a simple linear relation. The wider the tyre, the more rubber that is one the road. The profile has nothing to do with how much rubber meets the road.
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    It pains me to agree with Duncan.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Am I ignorant, but am I right in saying that if tyres are under-inflated, then more of the tyre than is advisable is in contact with the road, and if over-inflated is not the reverse true? Surely correct tyre pressures would affect/limit the amount of flexing in all types of tyre.
    I am a simple soul and to change from 215/50 to 225/45 assuming that the profile is the percentage of the width, would simply mean an increase in ride height of 6.25 mm on the 215's, and that would affect the speedo reading slightly.
    Please tell me if I am talking bull****. We are all here to learn.
  1. another tyre
    By cranny 27 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2011, 21:00
  2. Quick question about tyre widths.
    By mickydoos in forum Handling & Braking
    Last Post: 27th October 2009, 19:43
  3. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  4. 215/50/17 tyre
    By jonnye in forum Parts for sale
    Last Post: 14th September 2006, 22:08
  5. Need info on tyres and wheel widths
    By big phil in forum Suspension, Wheels & Brakes
    Last Post: 19th April 2006, 21:19
max tyre width on vectra c
