Likes Likes:  1
Results 1 to 10 of 24
Thread: Retro fit rear heated seats
    Regular Member Shaddex's Avatar
    Jan 2014
    North Staffs
    17 Post(s)
    Vehicle : 1.9
    Trim : SRI
    Engine : CDTI
    Mileage : 94000
    Default Retro fit rear heated seats
    Anyone added heat pads etc to the rear bench ?
    What's needed for the job ?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Are you using genuine or aftermarket kits ?
    aftermarket is much cheaper
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    This gives me another idea for a new forum section, we should have a section called modifying so all the stuff like this can be talked about in there to keep it in one place and easy to find if others want to do it
    I've done this to mine, check under your bench for the small connectors either side for the pads and for the switch connectors in the rear console they should be green for one side and brown for the other and go from there.
    Set of rear pads and rewire to car loom. 2 switches and panel to fit in, 2 relays for rec.
    im sure it's covered in the right section as that's where I took all my info from
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Jan 2014
    North Staffs
    17 Post(s)
    Vehicle : 1.9
    Trim : SRI
    Engine : CDTI
    Mileage : 94000
    I have no wiring in place. Its a Facelift lol....
    Looking for genuine unless aftermarket can use the genuine switches.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    39 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by Shaddex View Post
    IIrc dog_book had wiring in place as me and Happypostie fitted aftermarket heater mats to his leather ......
    Jan 2014
    North Staffs
    17 Post(s)
    Vehicle : 1.9
    Trim : SRI
    Engine : CDTI
    Mileage : 94000
    So aftermarket pads with vx wiring is the way to go. I'll get to my donor car and pull some more wiring out then lol.
    Administrator plasma's Avatar
    On the Forum
    574 Post(s)
    Engine : 150
    Mileage : 74000
    Yes, can be done... Fit OEM wiring and just change the plug which goes under the rear bench to one which comes with the heater mats so they are still unplug able
    PM happypostie as he has done this on his.
  8. Likes SRIDAN liked this post
  9. #8
    Jan 2014
    North Staffs
    17 Post(s)
    Vehicle : 1.9
    Trim : SRI
    Engine : CDTI
    Mileage : 94000
    @Sebastian don't suppose you have rear switches for sale ?
  10. #9
    Jan 2014
    North Staffs
    17 Post(s)
    Vehicle : 1.9
    Trim : SRI
    Engine : CDTI
    Mileage : 94000
    Cheers @plasma
  11. #10
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    Shaddex you dont have any wiring available for the front heated seats do you ?
  1. Info needed , heated seats , retro fit !
    By biffbangpow in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 22:38
  2. Retro fitting heated seats (front)
    By Keithy in forum Styling
    Last Post: 8th November 2012, 23:11
  3. Retro fit heated front seats
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2012, 07:02
  4. heated seats, possible retro fit??
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2010, 16:43
  5. rear heated seats???
    By adfrodsham in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 20:54
vectra c rear heated seats
