Thread: F23 cable adjustment
    Default F23 cable adjustment
    I've been told by a vx mechanic, to adjust the cable you lift the gearstick cover and open the grey/black plastic catch at the end of the cable then remove pin , adjust and put pin back, but how do you open the little grey clip/box thing without breaking it, please anyone know?
    morton
    which cable fella ?
    The gear linkage one that moves 1st to 2nd etc.
    morton
    whats wrong with it ?
    Gearchange a bit sloppy, need to tighten it up a bit, i've got cable ties on the g/box end at the mo, but it dont look to good, need to do the job properly really.
    Any mechanics out there?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Not much help mate but this is all I can find.
    5. Detach 2x shift cables from the manual shift lever
    Important: Open clamping piece as far as notch only, opening any further (overstretching) may damage clamping piece.
    • Detach selector cable from clamping piece (4)
    Note: Open clamping piece using a small screwdriver.
    • Detach shift cable from clamping piece (3)
    • Unclip 2x shift cables from counterhold (2)
    Note: Compress to release lugs (1)
    Thanks rushy, thats more than i found
  1. Renewing seat adjustment cable
    By Tigerfan in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 18:55
  2. 1.8 Petrol SRI 2007 Throttle cable adjustment?
    By sduk in forum Petrol Engine related
    Last Post: 1st August 2008, 21:12
  3. Gearchange cable adjustment
    By prm in forum Engine & Drivetrain
    Last Post: 9th October 2007, 10:09
f23 gear linkage adjustment
f23 adjustment
vectra c gear linkage adjustment
setting vauxhall gear cables
how to set up gear linkage on zafira f23
zafria 2006 gear cable adjustment
adjusting vectra gear cables
adjust zafira gear change cables
vauxhall f23 gear cable setup
vauxhall meriva diesel gear adjusment
vauxhall f23 gear cables
f23 gearbox cables
vauxhall f23 gear stick adjustment
f23 cable adjust
vauxhall zafira f23 gear selector adjustment
vectra c gear linkage adjusment
gear linkage adjustment vectr c
f23 gearbopx adust selecvtor cabkes
