Results 1 to 10 of 14
Thread: Power Steering?
    Regular Member vectrahuw's Avatar
    Feb 2007
    Wales
    confused Power Steering?
    I need to top up my power steering fluid but cant find where to put it!
    ive looked under the bonnet and in the book but with no luck.
    please dont laugh!
    thanx guys
    morton
    smallish bottle to the left of the engine bay looking in from the front ! its fairly close to the rubber seal infront of the plastic scuttle panel !
    Yes i've seen that, why is it so hard to get at.
    Feb 2007
    Wales
    ok clear/white bottle with black cap that says ONLY USE DOT 4 FLUID??
    its telling me on the bottle that its just below max. but it showed up on my trip computer a few times today? also my power steering warning symbol is showing up on the clocks.
    if so where's the brake fluid bottle!!??
    Feb 2007
    Wales
    got a 1.8 sri petrol by the way!
    That one is the brake/clutch res, the power steering one is behind the front bumper by o/s wheel.
    Feb 2007
    Wales
    i still cant see it!!
    is it under the battery somewhere?
    duz it have a yellow screw top?
    pics would be great or even a diagram!
    right,, contary to Veccy22's inaccurate info, the power steering resevoir and pump is to be found under the drivers side headlight..access is greatly improved by taking the front bumperskin off and you can get all the access to top it up you need and you can also see the levels better, there is a dipstick in the cap on top of the reservoir.
    Feb 2007
    Wales
    bumperskin?
    do u mean take off the bumper??
    or can i access it without removing this?
    nope, not without a lot of greif... the bumperskin is easy to remove.. takes about 10 mins...just undo the 3 screws in the front of the wheelarches that go into the bumper, prise out the 2 plastic plugs in the bumper by the headlights, and remove the 4 plastic plugs under the front of the car....then just start peeling the bumper out of the wing slides, put your hand in behind the bumper on the line that it joins the wing at, pushing it out, work forward on one side, then repeat on the other, and the skin will come off..
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
